It is currently Wed May 22, 2013 2:09 pm
 Post subject: bottom paint
PostPosted: Thu Jan 07, 2010 8:38 am
i have read lot of the posts here and looked up some manufacturers data and still am lost, so i thought i would turn to you smart guys for some help. Plan on painting the bottom of my monte carlo as soon as get her flipped back over upside down and the temps get out of the teens and to south carolina normal. can anyone recommend a good bottom paint to go over the epoxy? all i see in the catalogs is anti fouling paint i dont want cause the boat will be trailered. Will a two part top side poly be sufficient?
 Post subject: Re: bottom paint
PostPosted: Thu Jan 07, 2010 9:12 am
Lot's of ways to go here...most will tell you to not use top paint on the bottom though.
I believe Dave Lott used http://www.supermarinepaint.com/bottom-revolution-SM-1000.asp
I think Bill E used Interlux VC Performance
Oyster uses Kilz
Ken used epoxy with pigment
There are more out there. It also depends where you use your boat (salt or fresh water), how long it will be in the water at any time (1 day or 2 weeks)...
So give us a little more info on your criteria and well have better answers.
http://www.unitybuild.net
PostPosted: Thu Jan 07, 2010 9:19 am
I dealt with the same questions you had. My boat will be trailered and will run exclusively in fresh water so I really didn't need an anti-foul. Additionally, I wanted the bottom to be white.
Like you I considered a quality topside paint so I called Interlux and their tech support said that "topside" paints would not stand up to submersion very well at all. They recommended two bottom paints that would "suit my needs".
They have a bottom paint called Tri-lux II (only available in Canada) - the Canadian version of Trilux 33 (without the biocide - the particular type is banned in Canada) and ultimately the choice I went with - VC Performance Epoxy.
Here's the "blurb" on the VC --- "VC Performance Epoxy is a two-part kit ideal for trailered or rack-stored performance powerboats and sailboats. Formerly known as VC Underwater Epoxy. Produces a hard, slick, semi-gloss white finish with special additives to make wet sanding and burnishing easy.
VC Performance's semi-gloss finish makes viewing sanded areas easier. It contains no antifouling biocide. Overcoats have a 10 minute drying time. It can left to dry indefinitely before launching. Use with V170 thinner. Offers 320 Sq.Ft./Gal Coverage."
There is also a VC Offshore that comes in a few limited colours that uses Teflon instead of a biocide to help keep the bottom clean which could suit your needs if you are looking for a coloured bottom....
Graham
PostPosted: Thu Jan 07, 2010 10:54 am
I plan on going with the Supermarine TS-1000 that ttownshaw linked in his reply above.
After talking to Dave Lott about his experience with TS-1000 and its ease of application and seeing a boat with it at the Gathering, the choice was a no brainer for a freshwater trailer boat. The wide number of color choices with the Supermarine TS-1000 is icing on the cake for me.
http://www.supermarinepaint.com/topside ... M-1000.asp
My Zip build log...
PostPosted: Thu Jan 07, 2010 11:02 am
thanks guys,,,I knew there are a bunch of smart guys on here :D ,,,,the supermarine line looks like just what i need. seems the only other specific bottom paint i could find was anti fouling and i dont need it or want it,,, thanks again. Almost ready to roll her over,,the boat that is,, the wife rolls by herself
PostPosted: Thu Jan 07, 2010 11:25 am
Do not use Kiltz on the bottom of your boat at all under any topcoat or under any antifouling paints.
PostPosted: Thu Jan 07, 2010 11:36 am
Ok, Chris - Very big COMMENT on using Supermarine. The paint is silicon based and cures FAST, tight and hard. It is imperative that you lightly sand between coats at 320 grit or higher. If you fail to do this, the next coat cannot bond with the underlying coat and the fresh coat will draw up in a crinkled mess. Speaking from personal experience.
PostPosted: Thu Jan 07, 2010 12:12 pm
I am also building a Monte Carlo but it will be used in salt water and fresh water as well so what bottom paint do you guys think would be best?
John Amundsen
Monte Carlo
Winter Haven, FL
PostPosted: Thu Jan 07, 2010 12:35 pm
I run in the inter-coastal and bays with a trailer queen. I use VC Performance w/Teflon
PostPosted: Thu Jan 07, 2010 1:47 pm
I intend to paint the bottom and sides, dont know how the VC would look above the water line and a $250 a gallon,,,,wheeee,,, and really dont have plans for salt water and a few hours by chance wouldnt hurt a good quality paint i dont think,,,embarrassing as it may be, was at one time certified nuclear coatings inspector,,,alzheimers is a bitch :D
PostPosted: Thu Jan 07, 2010 2:06 pm
Chris
Supermarine should be fine for your plans.
John A may have different needs. I was just responding to what I have used in a similar situation.
PostPosted: Thu Jan 07, 2010 2:41 pm
Sorry Mike if I wasn't clear...I didn't mean to use it as a "primer coat" but rather a one coat (only coat). If this is not okay then please set me straight.
PostPosted: Fri Jan 08, 2010 1:13 pm
i guess i need to start shopping for paint, 4 hrs, myself, myself,myself and myself got the monte turned over again without turning it into half a ton of tooth picks. the vodka and oxycontin are waiting upstairs. Gatta get some help next time.
