It is currently Sat May 25, 2013 12:21 am
 Post subject: epoxy on cedar
PostPosted: Sun Jun 06, 2010 5:54 am
hi ,i was planning on useing white cedar for my deck > will epoxy R. make it tough enough as it is very soft wood,it would look great :!: mike im worried abut dings and dents 2 coats ??
 Post subject: Re: epoxy on cedar
PostPosted: Sun Jun 06, 2010 6:01 am
Epoxy, in and of itself, once fully cured is very hard. It has a hardness rating just a little less than formica. Therefore, it would provide protection for the cedar by itself provided it is not very thin.
However, a canoe, if used, suffers a lot of abuse. I would suggest you add a layer of protection and fiberglass it as well. This would also help stabilize the wood from all the torque pressures the canoe experiences (like being wrapped around a boulder). For the deck, you can go light on the glass, for example 3-4oz material but I would use heavier clothe for the bottom and sides, ie 6 oz.
PostPosted: Sun Jun 06, 2010 6:07 am
:!: :D thanks im building little hunk,i have alot of cedar and it is very nice looking ,i cant wait :!: mike
PostPosted: Sun Jun 06, 2010 10:06 am
Apologies, I don't know where the brain moment came with the canoe.
Nevermind, yes I do, I was looking at Bruce's old canoe just prior the post.
dave
PostPosted: Thu Jun 10, 2010 8:27 am
Yes, apply a light fiberglass cloth. Something like 4 oz is fine. It will provide a resistance to penetration and will control checking if ceder is prone to that (I'm not familiar with it).
Remember that epoxy needs uv protection. Color paint, clear paint or a varnish.
PostPosted: Thu Jun 10, 2010 10:12 am
hi, never thought clear pait,does it work good :?: look good :?: mike
