oleman, the primary consideration of stiffening a hull built of thinner material is to insure the new joints don't allow any flex. If they can flex most often the result is to crack/break/bend/distort or otherwise tear up the original boat. Thicker stock can be a good solution for many modifications as long as that new material doesn't get welded to the thinner material where the thin stuff can move.
A composite transom made of 5052 sheet and 6061 extrusions built up to a 2" thickness should hold a 70 vertically. Does t his boat have a tray along the inside of the transom? Many lighter boats have/had/were originally equipped with a sheet of aluminum joined to the transom at near right angle that kept water that came in over the stern, or spray, from getting into the bilges. This 'slop tray'/splash well/motor wash guard was a critical transom stiffening member as it formed a huge (thin) T with the transom.
If you're replacing the stock sheet metal and plywood type of transom with an all welded built up panel, I'd want to make sure there was a stiffening element that stopped the engine from flexing the entire transom aft as it pushed the boat. The primary force of the engine at the top of the transom is aft- not forward. The forward thrust happens lower at the bottom of the outboards' mount plates.
Welding a deck to the transom at deck level will act as a T there, at that level, but the T that will keep the transom from folding/bending/kinking back is the slop tray/wash pan at about 5" to 7" below the top of the engine's clamps at the cast mount which hooks over the stern/transom mount.
I can't say if the scantlings you've suggested are strong enough without pictures or drawings. Nice shop rate though, I wish we could charge that, and we're in Alaska! [where things are supposed to be more expensive.]
Cheers,
_________________ Kevin Morin
