It is currently Mon May 20, 2013 6:36 am
Post new topic Reply to topic  [ 122 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
PostPosted: Tue Nov 30, 2010 10:20 am
slug wrote:
Thanks guys; Ben2go...never going to happen...already got the drive train . (and cruising plans of course :lol: :lol: .
A boat is a hole in the water in which I throw money into.
PostPosted: Tue Nov 30, 2010 12:16 pm
Good news; :) The turn went really well . Had an old friend Dave Harris helping me. Dave's one of those guys I've worked with on various projects ( he helped me build the hull and cabin on my 34' sailboat ) and we work really well together. We anticipate each others moves all the time...a real pleasure.
A controlled turn using 4 chain hoists, 4 slings and some controlling ropes. No surprises.
The boat sits well on the cradle and is easy to move around (with the brakes off)
Really impressed with the size of the boat...it looks huge for a 21' 6" hull...plenty deep and wide. Can't wait to get going on the inside now.
Pics to follow as soon as it quits raining.
PostPosted: Tue Nov 30, 2010 12:40 pm
Just wait til it gets wet,it'll shrink!!! :wink:
Congrats on the flip :D
PostPosted: Tue Nov 30, 2010 12:42 pm
Latest photos.
PostPosted: Tue Nov 30, 2010 7:01 pm
Now comes the tedious detail work that seems like it takes forever to complete.
PostPosted: Tue Nov 30, 2010 9:51 pm
Slug,
I normally would have waited until the launch, but you have already earned your's. Impressive Sir. :D
http://www.youtube.com/watch?v=ElruJMYilow
PostPosted: Sun Dec 05, 2010 6:47 am
Well, couldn't be helped :wink: . Just had to set the engine and tranny in place and set up some temporary cabin sole beams to see where everything was going to end up. Looks great....lots of room. Now to get down to the dirty work, sanding and encapsulating. Good to boost your spirits once in a while.
PostPosted: Sun Dec 05, 2010 8:40 am
Please refresh my memory on the engine type and gear.
PostPosted: Sun Dec 05, 2010 11:42 am
Engine is a Kubota 1105 diesel 3 cyl 29 hp., similar to that used in the Beta Marine 30. Bellhousing and adapters are from Hayes in Michigan (great supplier ) After having the sailboat with all the thru hulls and water entrances, I decided to go with a dry stack exhaust and keel cooling, using a cooler outside the bottom of the hull.The engine as supplied comes with a fan, so I'm going to build a shroud for it and pull some cooling air from the side deck area and blow it past the engine and up the stack past the muffler to help cooling. Think it will work. I have a similar engine in a tractor and am very impressed with the way it works and stretches fuel. Only time will tell.
PostPosted: Sun Dec 05, 2010 11:43 am
Sorry; Trans is a ZF 10 with 2.72 gear ratio.
PostPosted: Sun Dec 05, 2010 2:37 pm
Oh yeah,that's gonna be a sweet set up.Nice compact fuel mizer.Looks great.Please give us lots of details on the engine compartment and exhaust stack.This stuff is excellent for insulating dry stacks. http://www.fireplacesnow.com/viewPrd.as ... duct=49501
PostPosted: Fri Dec 24, 2010 12:22 pm
Well, working away at encapsulating the interior....slow, tedious job. Since I'm using an industrial (as compared with a marinized) Kubota, I had to fabricate the mounts.
It went well and they turned out as hoped. Will send pics shortly. Working on engine beds now.
Merry Christmas too all, and have a great boating New Year. :)
Doug and Verna...the "Slug" team.
PostPosted: Fri Dec 24, 2010 12:30 pm
I know a guy that has that engine on an old VW Bug based buggy. He claims 100 mpg. It is flatland and probably 55 mph max.
PostPosted: Sun Jan 16, 2011 3:18 pm
Got the engine beds/stringers/mounts pretty well finished.
File comment: This is the nearly completed setup. (still needs the angle brackets from the stringers to each frame) Note the rear engine mounts I had to fabricate as there weren't any on the bell housing for this industrial engine. Still have to drill for mount bolts.
File comment: This is one side of the stringers,laminated out of 3 layers of Baltic birch and epoxied. Note how they fit around 3 frames.
File comment: This is the setup I used to get my initial alignment. The wire runs thru the centreline of the shaft, and from there I calculated the trans offset and screwed the temporary ply pieces to indicate the inside corner of the rails
PostPosted: Sun Jan 16, 2011 6:26 pm
Awesome build.
My Zip build log...
