It is currently Fri May 24, 2013 6:21 am
 Post subject: no power
PostPosted: Mon Jan 10, 2011 2:58 pm
Ok I hooked up my battery to my 25 hp mercury outboard with electric start and hooked the wiring harness to the boat to test some lights and noticed I had 2 wires touching, and nothing seemed to work, thinking I blew a fuse the only fuses I know of are the inline fuses between the radio and lights, those are fine, I hooked the battery directly to the boat wiring after the ignition and all the electronics in the boat work fine. The boat does have a kill switch so I checked that, my question is, is there another fuse somewhere? Maybe in the engine? I have nothing when hooking battery threw the engine.????
 Post subject: Re: no power
PostPosted: Mon Jan 10, 2011 2:59 pm
Also I used to be able to crank the engine but I get nothing now.
PostPosted: Mon Jan 10, 2011 5:21 pm
most newer engines have a fuse under the cowling useually right at the starter
PostPosted: Mon Jan 10, 2011 6:39 pm
The 25 Merc's have an in-line fuse under the cowl.
The diagram should help you locate it.
Graham
PostPosted: Tue Jan 11, 2011 9:31 am
Ok I found a fuse holder it was mounted to the back near the plugs, I opened it up and the fuse came apart, now I have both halves stuck in the holder. Does this sound like the right one? The fuse holder looks to be coming off the wire harness inside the cowl. :? :?
PostPosted: Tue Jan 11, 2011 9:40 am
yes sounds right but what do you mean the two halves is the fuse broke in half?
PostPosted: Tue Jan 11, 2011 10:19 am
Yes when I pulled the fuse holder apart the glass piece on the fuse came off and left the metal end in the other half, I put some wd40 in to get it loose.
PostPosted: Tue Jan 11, 2011 10:38 am
just replace the fuse and you should be good to go.
PostPosted: Tue Jan 11, 2011 11:26 am
95 cents later all good!!!!! Thanks! :D :D :D :D :D
PostPosted: Tue Jan 11, 2011 3:46 pm
Don't forget to carry at least one extra fuse with you when it's done! :wink: 8)
