It is currently Tue Jun 18, 2013 9:27 pm
Post new topic Reply to topic  [ 98 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Sat Jan 29, 2011 10:49 am
here is a pic of the bow spreader template prior to tranfer to the wood.
PostPosted: Sat Jan 29, 2011 10:34 pm
Jeff,
Something that I picked on and it saved me alot of time. The only thing you need to pattern is the stems and you have already done those. Everything else is straight lines. Take your bow spreader for example. Cut your material to the longest lenght, mark your center line like you did on your pattern and then take the shorter lenght and divide by two. Measure from the center out, mark and draw your straight line to the top corner. The same applies for your bulkheads. :D
Once you get your bulkheads mounted to the form you need to notch out the form on each side of the stem and where the sheers cross over the form so you can have a little overhang. If not you will come up short when you attach the sides to the stems. :roll: :oops: It only happened to me once. :wink: :lol:
PostPosted: Sun Jan 30, 2011 7:54 pm
Chip, thanks for the input on the patterns. I'm probably over-doing it. I like your idea of using the centerline and working out from there. I think that method will work great for the bulkheads. Also, thanks for the advance warning on the building form at the sheer intersection. I could see that being a problem if not relieved (notched).
Jeff
PostPosted: Wed Feb 02, 2011 4:48 pm
Well, here is the garage workshop after the blizzard. I still plan on working out there this weekend when the temps get up toward 30.
View from inside shop. Building form to the right.
PostPosted: Wed Feb 02, 2011 4:53 pm
You guys are wacko!!! I'm cold just looking at that!! :shock:
PostPosted: Thu Feb 03, 2011 3:41 am
:shock: That's just not right :? People should not live in places that cold! :roll: :lol:
PostPosted: Sat Feb 12, 2011 11:44 am
Well it has acually got up to 33 degrees today so I was out in the shop leveling and aligning the building form. Bulkhead layout is next. Pics to follow.
PostPosted: Sat Feb 12, 2011 12:35 pm
Pic is of bow spreaders. Note inward taper toward front.
PostPosted: Tue Mar 01, 2011 12:30 pm
It finally got warm enough to work outside today. I am laying out six bulkheads A (for the 20 foot Huck Finn). If you look closely in the pic you can see the markings. What looks like wasted wood in the center of the sheet will be used for butt blocks. I wanted one piece bulkheads vice the two piece.
PostPosted: Tue Mar 01, 2011 1:56 pm
Here is what the bulkheads look like temporarily stacked on the building form. Note centerline.
PostPosted: Sun Mar 13, 2011 5:14 pm
Six bulkheads A and 12 side frames. Breaking out the Poxy Grip next.
PostPosted: Sun Mar 13, 2011 5:19 pm
You will have those bulkheads on that form in no time. :D
PostPosted: Sun Mar 13, 2011 5:25 pm
Right, and probably be in the water before another active member and poster thats building one will too. too. :lol: :lol: :P :oops: :twisted: :lol:
PostPosted: Sun Mar 13, 2011 5:28 pm
:shock: Who me :roll: :oops:
PostPosted: Sun Mar 13, 2011 5:37 pm
Heck I thought he was talking about me. :lol:
John Amundsen
Monte Carlo
Winter Haven, FL
