It is currently Fri May 24, 2013 10:19 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
 Post subject: Glen-L 10
PostPosted: Wed Mar 23, 2011 1:06 pm
Hi
I have started on this one. Greate drawings from Glen-L.
I`l keep you uppdatet.
Don`t get hang up in the language. I`m from Norway.
Jan F.
File comment: In my basement. Caos? Not for me!
File comment: Parts
 Post subject: Re: Glen-L 10
PostPosted: Wed Mar 23, 2011 1:22 pm
Welcome Jan.
Don't worry about language.. we will figure it out.
Use photo's... we love to see them and can help better when we can see the project.
Ian (aka Iggy)
My Malahini Build
PostPosted: Wed Mar 23, 2011 1:31 pm
welcome Jan
PostPosted: Wed Mar 23, 2011 3:18 pm
Welcome Jan,
Boatbuilding is a language all its own, and pictures paint a thousand words. Great start on your boat, and thanks for the photo's. :)
PostPosted: Thu Mar 24, 2011 12:40 am
And so it begins......
Keep us up to date & feel free to ask questions.
PostPosted: Thu Mar 24, 2011 3:57 am
Welcome Jan - Keep the pictures coming. Looks like you making some serious progress already.
And please do not worry about the language. Obviously, you have not read some of the threads. The locals have a hard enough time with it. :lol:
PostPosted: Thu Mar 31, 2011 12:20 am
Guess this have been discussed before, but: I have trubble finding marine plywood here in Trondheim. I have used ordinary waterproof plywood on an other boat I have build. I covered that one with fiberglass, but that turned out to be expensive. The Glen-L 10 is going to be on land when not in use. Would it be enough to just paint the hull?
Fiberglass tape and epoxy on the joints.
PostPosted: Thu Mar 31, 2011 1:24 am
It's all about the transition from water to land.
I'd try to glass the underwater part at least, otherwise when each time you pull onto a beach, or a trolley, you'll dent the ply & let water in,
I did a test of Ply vs Glassed Ply.
I hit them both with a rock.
The Ply dented badly.
The Glassed Ply scuffed a little.
I know which I'd prefer as I dragged my boat up onto a beach.
PostPosted: Fri Apr 01, 2011 3:55 am
Clear answer. I`l try to find a cheaper brand of fiberglass then.
West System is a "bit" overpriced I think..
PostPosted: Sat Sep 10, 2011 1:48 pm
Done some progress..
PostPosted: Sat Sep 10, 2011 1:58 pm
This is one of those instances that if you can at least find some polyester resin and some fiberglass, I see no real reason why you cannot use that type and get the same amount of use out of it. As long as a small boat is sailed from a trailer and taken care of, keeping water from standing in the boat too for long periods of time, you should be fine.
Keep in mind that the polyester dries quicker and does has some fumes that the epoxy resins do not have, even though epoxy also has its issues too. Satuate the wood completely and the apply the glass after you have fitted your glass in the dry stage. Then remove it and handle it with care. Place small marks on the corners and at several other points along the chines when you are fitting your glass so that you have some reference point when you go back and apply it over the wetted wood. I use sharpie type pens which is not a problem. Just make small lines.
Oh for what its worth, I am one of those folks that Dave Lott was talking about. I sputter on a good day and in the evening time with my half way blindness and febble mind, I have a bad habit of creating another dialect on its own. :wink: :lol: :lol:
PostPosted: Sat Sep 10, 2011 2:33 pm
A small quart of good marine (Epiphanes) paint, $50. A gallon of Epoxy (East Systems) $100. Painting would cost more for the same amount of protection and you don't absolutely need to put glass in it if its light duty.
Stuart
( how do you say Hooter girly in Oyster dialect? )
PostPosted: Wed Sep 14, 2011 2:14 pm
"you don't absolutely need to put glass in it if its light duty"
With 4 mm of ply between me and the sea..there will be glass :)
PostPosted: Wed Sep 14, 2011 2:24 pm
Bah, more than enough. Real seamen just wear lifejackets and head out into the storm singing sea shanties and drinking rum. :wink:
Stuart
PostPosted: Wed Sep 14, 2011 3:23 pm
Rum??? :shock: :D
