Golf Cart Motor overheating
Ary
Re: Golf Cart Motor overheating
Postby Ary » Thu Oct 19, 2017 5:33 am
I don't know. But, my guess is that a golf cart motor rarily runs for 45 minutes. That is a fairly long run for most of use anyway.
irie E
Postby irie E » Thu Oct 19, 2017 12:22 pm
Do you know what the amp draw is at your cruising speed? And do you know the continuous duty rating of your motor?
ian231
Postby ian231 » Fri Nov 03, 2017 12:04 am
khundley wrote:I recently read where someone used square tube bent around the motor, maybe the same post Fergal referred to....that might help get better heat transfer than a round coil. jUst a thought.
The guys that race (very high speed) electric and also
2 stoke Radio Control boats use water to cool the motors / engines. Try some small diameter copper tube around the outside of the motor, one end is under water facing forward, the other exits behind. Some have the inlet behind the prop and exit above the water.
Return to “Electric Power”
