Building The Vera Cruise
Re: Building The Vera Cruise
I buy the pre-filled cartridges from System Three already filled with Gel Magic or West 10/SIX cartridges. I do not buy empty cartridges or mix and put epoxy into empty cartridges. I am not aware of any MFGs that make or sell empty u-Tah cartridges that can be filled by the consumer.
Hi, Carl, how about using something like a quart size freezer bag? Cut off a small section of one of the corners, fill with epoxy, then use it like a pastry bag. I have not tried this myself, just brainstorming.
That sounds like a good idea! I'm running out off places to glue. But, I may try it just for future reference. Mix what you need. Put it in the bag. Use it. Throw away the evidence. Cheap Trick.
I also think that is a better way than trying to stuff epoxy into a tube.
That is a good idea Matt.
I think there might be less waste this way as well. When I get to the gluing stage on the planking, I will give it a try.
KenRas
Post by KenRas »
Will the heat from the chemical reaction be hot enough to melt the plastic? Might mix up a small sacrificial batch first and wear heavy gloves
I haven't had a batch of epoxy heat up enough to melt anything. It gets rather warm if its in a concentrated mass but that only serves to speed up the reaction and decrease pot life. It is an exothermic reaction but a typical sized batch that you would be using for glue-up is not going to release enough energy to cause any real damage, especially since it will probably be used up within about 10 minutes. I say use a freezer bag so it doesn't tear but I wouldn't mix up an entire quart of thickened epoxy.
Benj269
Post by Benj269 »
In response to the plastic bag approach to epoxy squirting, you can also get couplers:
http://www.amazon.com/Ateco-4-Piece-Set ... ke+coupler
They turn a plastic bag into a piping bag, or in this case an epoxy bag. You could then use cheap pastry tips in any shape or size to more effectively guide the epoxy into its destination. It would probably be more user friendly and accurate than just cutting the corner off the bag.
Got my planking plywood today. Also ordered a bunch of screws and two drain plugs which are on their way. Starting to get more real!
Starting the un-crating. I'll be storing them all on the port side of the boat and moving around as needed.
That will keep you busy!!!!!!
Roberta :D :D :D :D :D
Yes maam!
Ranny
Post by Ranny »
May be a little late, but, I use this great tool when moving plywood.
http://www.gorillagripper.com
Saved my back when I had to rebuild a floor.
Ranny
garrech
Post by garrech »
I'll second hoodman's ziplock bag idea. I read about it somewhere on this site a few years ago when I was building our Kidyak. I used it to make the filets. Made things much easier to work with and clean up.
garrech
I think I remember that thread.
Mike, ctboater, do you know where it is?
sscobra
Post by sscobra »
Nice looking ply Carl. Where did you end up ordering it from? Skip
