Seattle Barrelback progress
Postby neel thompson » Sun Oct 01, 2017 9:44 am
Robert, My deck planks are 2 3/4" wide, 3/8" thick with 3/16" inch spacing between planks... I used thin screws with wide washers in the space between planks to hold them down while the epoxy set. I stained the deck and then put about 8 coats of varnish on the entire deck before I caulked the joints. I used 3m 4000 UV (black) to fill in the grooves. Then after that set up, I applied about 5 more coats of vanish over the deck boards and the caulking. I did not use any fiberglass cloth anywhere above the waterline. Your boat is really looking great.... Neel
RobertCugini
Postby RobertCugini » Wed Feb 07, 2018 9:37 pm
Making progress...
Postby Jimbob » Thu Feb 08, 2018 8:39 am
Looking good!
Looks like you will be bungin' soon!
aka bungman
vx929
Postby vx929 » Wed Feb 14, 2018 3:14 pm
Robert,
Very nice job on your boat. I am a local guy as well in Maple Valley (Hobart) and building the same boat you are. Can I ask you where you got the veneers from? Cross Cut has the Sapele I want to use, but I don't have the type of band saw need to cut them myself.
Any input would be appreciated.
Vince X.
vx929@comcast.net
RobertCugini
Postby RobertCugini » Wed Feb 14, 2018 8:10 pm
I bought enough veneer for two boats, and at this stage I would like to sell the extra.
It is from Certainly Wood in NY and it is extra thick African mahogany. Its thickness is 1/6th of an inch or 4mm.
I suggest you give me a call and we schedule a time to meet and you can see the boat and supplies.
Boat is in a location in DT Renton.
Robert
vx929
Postby vx929 » Thu Feb 15, 2018 10:33 am
Robert,
Send your phone number to my email.
vx929@comcast.net
Vince X.
Users browsing this forum: Google [Bot] and 4 guests
