upholstery
All things related to upholstering your boat.
Moderator: billy c
travis24
upholstery
Post by travis24 »
Trying to find different size crashpad rubber looking for something about 2 1/4" . Where is everyone buying there material from? Travis
Measure Twice, cut Once.
https://waterhogsworks.com/
Re: upholstery
Post by billy c »
Travis- that's a little wide for the standard crash pad, but if it is mounted on the flat surface you can always use a hidem strip or welting/cord to gain the difference.
here is a source for the 1 1/2" :
http://www.classicboatconnection.com/fl ... nnants.pdf
-Billy
travis24
Re: upholstery
Post by travis24 »
Billy,
Thanks for the reply. I was able to pick up the thread back in 08' on this topic. There needs to be a upholstery section on Glen-L. The 1 1/2 that classic boat connection sells that is the only size ? Are there other suppliers out there that make more sizes or would I have to customize something. Travis
fergal butler
Re: upholstery
Post by fergal butler »
I did mine with pipe insulation and a bit of plastic piping.
Re: upholstery
2 1/4" is about the size of a swim noodle.
Re: upholstery
Post by billy c »
Bill Edmundson wrote:2 1/4" is about the size of a swim noodle.
that would work :)
bet you could cut that with an electric carving knife like i do when shaping closed cell foam for cushions
-Billy
Re: upholstery
A pocket knife works well for cutting them. They are closed cell and flexible. They're are about $1.50 with tax. They are 4 feet long. But, you can join them with Weldwood Contact Cement. They are the same material as life-vest floatation.
Your choice of colors of coarse! :wink:
travis24
Re: upholstery
Post by travis24 »
What thickness of foam is everyone going with on there seats? 2" Also upholstery staple guns?
Travis
Re: upholstery
Post by billy c »
much would depend on the density of the foam and what you want the edges of the cushions to look like. some are wrapped in batting to soften the lines and others are built up similar to a box spring and mattress with 2 layers of foam attached together. a firm layer with a softer layer above. more variations of this too depending on pleats etc. or replicating a vintage "loose" kapok filled cushion"
Sailrite http://www.sailrite.com has some good videos of making a box cushion, i have a few book recommendations if you are headed down the automotive type of upholstery route.
-Billy
cusoak
Re: upholstery
Post by cusoak »
Sean. That is great looking crash pad. I am going to put crash pad on my zip.
I was wondering if you could share how you got the vinyl to form around the foam crash pad material.
Did you glue it on and then glue it all in place. Nice looking inside corners.
Jeff
fergal butler
Re: upholstery
Hi Jeff, I used contact spray glue to stick the vinyl to the foam leaving about 1/2" over hang each side and brush on contact glue for around the tubing that was then stapled around the cockpit and the crash pad overhang was stapled on top of that using plastic strips along the length of it to give a tight even fit.
slug
Re: upholstery
Post by slug »
Trisailer had a description of his upholstery procedure on his Gentry build...lots of good pictures there.
cusoak
Re: upholstery
Post by cusoak »
Doug, how might I find Trisailer port on his Gentry
Jeff
slug
Re: upholstery
Post by slug »
Jeff; Had a look and I think this is the thread.
viewtopic.php?f=2&t=13820&hilit=upholstery&start=240
wags86
Re: upholstery
Post by wags86 »
Wondering if anyone has herd of neoprene crash pad. I was told it holds up much longer and is better to work with.and if so where it can be found? Thanks wags86
Return to “Upholstery”
