Mr John
Lowka53
Re: Mr John
Post by Lowka53 »
:lol: yep a restart I had put the frames together last year before the heat got to me its already pushing 90 degrees here but I made sure I have ac and in a covered building area 8) this time. tomorrow I will be putting together the stern frame and finish the scafing of the sheers its is a good thing epoxy does not have a shelf life what I have is a few years old :lol: but I had used some last year and was still good i also have some stuff I am testing for Gail that I plan to use as well. :wink:
14' Mr John-being built
32' Supper Huck-in design
Rod H
Lowka53
Re: Mr John
Post by Lowka53 »
8) I got some work done in last couple of days I scarfed the chime logs, together Boy do I have some clean up to do on them.
I put the stern together and mounted it to building form
the Chime logs ready to install
the chime log temporary fitted I have a hump between frame one and frame two on both chime logs but can take it out by temporary clamping a four foot level to it to take out the hump it changes the curve going to the bow when I do this. once the side plywood sheeting is installed it should be stable and I can remove the level. Well that is what i have done so far today. I am not that far from sheeting now I do not see much shaping of the chime logs to get the ply wood to make good contact.
Rod H
Lowka53
Re: Mr John
Post by Lowka53 »
:lol: I found out I had a hiccup on my stern frame. I had it out of alinement after I had epoxied the chime logs in I noticed it. I must have set it to soon after my daily meds, I was a half inch off my center mark, it was looking right at me :lol: and the height was wrong got to love side effects to my meds I usually take a nap before I do anything after taking them I think that morning i went straight out and went to work. :roll: ( where is my sign :lol: )
Rod H
Lowka53
Re: Mr John
Post by Lowka53 »
:? well the weather in the Rockies has decided winter has not gone yet we have new snow in the mountains I am glad I decided not to go camping this last weekend I would be snowed in right now. but it is getting cold in the valley and a lot of rain at least at my house :shock: we usally have around 80 to 90 degree weather at this time of the year :| the build is on hold until payday I don't have enough epoxy or the ply wood yet so waiting on funds :wink:
Rod H
Lowka53
Re: Mr John
Post by Lowka53 »
:evil: well the winter got my temporary building shop I was using for this build I have to start again on putting another one up the wind took the last one and bent the metal frames to pretzels but the covering survived it and keep the build dry. we have been having a very strange spring going from snow to 80 degree weather in the same day. it should be stabilizing soon so I a can get things uncover and new shop put in. the lakes are open and here I sit with out my fishing boat done. Got to get off my old lazy butt and get some of my many project completed :oops: everybody else projects looks to be coming along great and I see some master pieces being built once again :wink: 8)
Rod H
Re: Mr John
The area you live in is so beautiful, it's a shame it has to be cold for so long up there. Sorry to hear about the shed. Another item for the list of challenges. Keep on pushing!
Lowka53
Re: Mr John
Post by Lowka53 »
Carl yes it is a beautiful place actually the weather is not that bad but it is hard to plan anything at time once we get from the spring we get the heat I keep push I am just a stubborn old coot lol
Rod H
Cabron
Re: Mr John
Post by Cabron »
Looking good. How many builds have you got going on? 2? 3?
specialk
Re: Mr John
Post by specialk »
Hey Rod ... sorry to hear about your shed... hope you get that worked out ...glad you getting some building time... sawdust does wonders for the soul....
2nd Boat.....?
Lowka53
Re: Mr John
Post by Lowka53 »
Cabron wrote:Looking good. How many builds have you got going on? 2? 3?
well I have started on 2 have a Donner I still need to get stripped
It has a good portion of parts for a v6 to be converted. I need to get it off the ground so I can check the a1 out-drive
Rod H
Lowka53
Re: Mr John
Post by Lowka53 »
the weather just don't want to give me a break I have only been seeing a few hours of sunshine on and off otherwise rain. I am afraid to uncover the boat to work on her and repair the temp build shed. I am feeling like I am living in Ohio again I don't ever remember this much rain here in may heck I have not even got my garden in the ground never drys out long enough to get it tilled. Oh well I get it one of these days
Rod H
BarnacleMike
Re: Mr John
Post by BarnacleMike »
Is that a roughly 1990 Bayliner Capri? Man, I've got fond, fond memories of one of those things!
tcough
Re: Mr John
Post by tcough »
This was the first boat I ever built, back in the early 80's. I don't know how many blisters I got driving in all the screws by hand! Was a fun little boat, but my brother talked me out of fiberglassing it so it leaked everywhere the first time out. Was fun building though and enjoyed the boat.
Happy Boating,
Tracy
Building a 19'-9" Flats Flyer
Re: Mr John
Post by chugalug »
Good to see you working on something.I tried an outdoor garden once.decided it's easier in planters Tomatoes and potatoes are going nuts.Could you look in your archives about the Envirotex I'm using for epoxy.(any negative stuff)its epoxy and waterproof mix is 1:1 with hardener.equevalent to 50 coats of varnish.using it with cloth on the bulwarks only so far-might use it to encapsulate floor support timbers.
Lowka53
Re: Mr John
Post by Lowka53 »
BarnacleMike wrote:Is that a roughly 1990 Bayliner Capri? Man, I've got fond, fond memories of one of those things!
I don't know what year it is I have never gotten the title yet almost afraid to strip it for parts
:roll:
Rod H
