Wood filler with Epoxy
bjfrater
Postby bjfrater » Thu Feb 12, 2015 12:39 pm
Hi,
Can I use any wood filler to fill screw holes and gaps on the hull of my boat prior to covering with Epoxy?
Im using West System epoxy and I was wondering if there were certain types of filler that I shouldn't use?
Re: Wood filler with Epoxy
Postby Roberta » Thu Feb 12, 2015 1:10 pm
I would avoid any oil based fillers. You could use sanding dust mixed with resin to make a filler. There are many two part epoxy based fairing compounds out there as well. They are easier to apply and sand.
bjfrater
Postby bjfrater » Thu Feb 12, 2015 7:57 pm
Ok i will look around for some non oil based ones. What did you use Roberta?
Postby Roberta » Fri Feb 13, 2015 6:03 am
I like System Three Quick Fair or, if I want some extra strength, like in fillets , I use their Easy Fillet. Both available through Glen L.
Andy Garrett
Postby Andy Garrett » Sun Feb 15, 2015 7:40 am
Poxy Grip or Poxy Shield with saw dust is an easy and color appropriate option.
Andy Garrett
BlueRidgeBoater
Postby BlueRidgeBoater » Mon Feb 16, 2015 3:14 pm
I just bought some Famowood to use based on some recommendations elsewhere. Will it darken like mahogony does, though, when epoxy is applied to it?
Postby chugalug » Mon Feb 16, 2015 5:12 pm
:D I used Epoxy Shield and silica and microballoons .even tried sawdust.Everthing worked good .Make sure you mix the hardener and resin thoughly(about 2 minutes) then slowly add the powder mixes.I mixed equal amounts of silica and micro ahead of time and then added to resin mix.should be like peanut butter the video says.
cusoak
Postby cusoak » Tue Feb 17, 2015 5:41 am
I used Mahogany Famowood to fill my screw holes and when I finished staining the sides you could not see the filled holes.
Jeff
Postby billy c » Tue Feb 17, 2015 5:44 am
BlueRidgeBoater wrote:I just bought some Famowood to use based on some recommendations elsewhere. Will it darken like mahogony does, though, when epoxy is applied to it?
match fillers to wood that has not been freshly planed so you get a closer color match. the famowood is used by many with success, but i prefer using epoxy filler if i am using epoxy to encapsulate the hull. more likely to shrink and expand at the same rate over time
Return to “Epoxy”
