Aussie Gentry
John R
Re: Aussie Gentry
Postby John R » Fri Sep 30, 2016 4:09 pm
G/Day well fitted a plastic water pipe into the shaft hole using Bote-Cote epoxy makes for a neat and waterproof fixture......John
John R
Re: Aussie Gentry
Postby John R » Sun Oct 02, 2016 3:14 pm
G/Day well got stuck into a sheet of 316 Stainless and used a plasma cutter for the first time i bought this thing 5 years ago, it worked very well so here is what i did ....John
Re: Aussie Gentry
Postby Roberta » Sun Oct 02, 2016 3:51 pm
Looking great. Are you going to Tig weld the cutwater?
jenko
Re: Aussie Gentry
Postby jenko » Sun Oct 02, 2016 5:25 pm
John when I did my cutwater ,welding the two halves together caused the whole thing to shrink along the seam weld ( I used a tig) which in turn meant I needed to cut a few slits in either side and reweld to get it to fit .
the warpage was as bad as when the top was snug fit the bottom didn't mate up by 50 mm
John R
Re: Aussie Gentry
Postby John R » Mon Oct 03, 2016 11:51 pm
G/Day Roberta / Jenko yes i will tack weld on the boat fires then make some outside molds and screw on to the molds then tig weld the inside, then make some internal molds and screw the cutwater to them and tig weld the outside this process should stop any distortion ...watch this space :lol:
John R
Re: Aussie Gentry
Postby John R » Sat Oct 15, 2016 2:52 pm
G/Day well weather is great in Oz now so i got 2 coats of epoxy primer on the transom (Bote-Cote) and also a flow coat stain on the sides now i will see what i am sanding .....John
John R
Re: Aussie Gentry
Postby John R » Sat Oct 15, 2016 8:20 pm
G/Day well sanded off the guide cote looked good and felt good, so the first primer coat of epoxy went on .....John
John R
Re: Aussie Gentry
Postby John R » Sat Oct 15, 2016 8:21 pm
Re: Aussie Gentry
Postby Roberta » Sun Oct 16, 2016 5:48 am
NNNIIIICCCCEEEEE!!!!
Roberta :D :D :D :D :D :D :D
ian bell
Re: Aussie Gentry
Postby ian bell » Sun Oct 16, 2016 1:28 pm
Hi John .Great work ,love the finish.
Ian
Re: Aussie Gentry
Postby Bill Edmundson » Sun Oct 16, 2016 2:11 pm
Looks great! But, sanding it will be heart breaking, until the clear-coat goes on!
John R
Re: Aussie Gentry
Postby John R » Tue Oct 18, 2016 9:49 pm
G/Day all and thanks yes Bill i am lubing the elbows now :D got the second primer coat on now to do this all again on the other side, most of the grain has filled so maybe only 6 coats of finishing clear ?????......John
John R
Re: Aussie Gentry
Postby John R » Thu Oct 20, 2016 5:17 pm
G/Day well second coat of epoxy primer on now to prepare to glass the bottom and make the trailer runners ....John
John R
Re: Aussie Gentry
Postby John R » Sat Dec 10, 2016 3:17 pm
G/Day well i have 5 coats of epoxy primer on both sides, i was thinking during the night that how am i going to get into this boat if i am not at a wharf / jetty and it has no cav plate to step on to, so i made a solid Mahogany step bumper and side trims took a bit to fit the rear peice will be held by epoxy and 5 off 3/8" S.S long bolts through the transom
John R
Re: Aussie Gentry
Postby John R » Sat Dec 10, 2016 3:18 pm
Users browsing this forum: No registered users and 22 guests
