Aussie Gentry
rleete
Re: Aussie Gentry
Postby rleete » Sat Dec 10, 2016 7:42 pm
Looks good. Nice how the side trim leads right into it. Makes it look more integrated and less just tacked on.
speedracer
Re: Aussie Gentry
Postby speedracer » Sun Dec 11, 2016 7:44 pm
John - Your build is looking great. I had the same concern about getting in my Monaco from the water. How wide did you make that step at the stern? Also, how far above the bottom did you place it?
John R
Re: Aussie Gentry
Postby John R » Sun Dec 11, 2016 11:31 pm
G/Day Speedracer thanks for that ok i made it 200mm down from the bottom center and 170 out from that point i have a total of 5 by 3/8" S.S. threaded rods picking up solid timber inside the transom and the outer 2 from the center pick up brackets at the engine bearers, also epoxy the bumper / step to the transom hope this helps ......John
speedracer
Re: Aussie Gentry
Postby speedracer » Mon Dec 12, 2016 5:45 am
Yes, that's what I needed. I am thinking of something similar. Thanks.
John R
Re: Aussie Gentry
Postby John R » Tue Dec 27, 2016 3:13 pm
G/Day well got the edges done in 6oz glass using Bote-Cote epoxy resin and for the first time using peel ply as well my first attempt was pretty good better than 80% my second was neary 100% and the finish is so smooth, i will do the stem next and then the compete bottom now that all the hard bits are done and also i have a handle on the peel ply ......John
John R
Re: Aussie Gentry
Postby John R » Tue Dec 27, 2016 3:14 pm
jenko
Re: Aussie Gentry
Postby jenko » Tue Dec 27, 2016 3:55 pm
looks good John ,I contemplated using peel ply now I wish I had
John R
Re: Aussie Gentry
Postby John R » Sat Jan 14, 2017 3:49 pm
G/Day well we got the glass down on the bottom yesterday weather was great and got the peel ply on as well here are some photos ........John
John R
Re: Aussie Gentry
Postby John R » Wed Feb 15, 2017 10:24 pm
well the boat is now ready to prime and paint to the water line the finish after taking the peel ply of was great took 2 hours to sand smooth and get another 2 coats of epoxy primer on, then sanded back total sanding time 4.2 hours.....John
John R
Re: Aussie Gentry
Postby John R » Sat Feb 18, 2017 6:41 pm
G/Day well steering wheel is cleared and finished also the bottom has been sanded and finished and cut tape on 2" below the waterline mark this 2" section will be gold so tomorrow i will get the Luxapoxy primer on ......John
John R
Re: Aussie Gentry
Postby John R » Sat Feb 18, 2017 6:42 pm
John R
Re: Aussie Gentry
Postby John R » Fri Feb 24, 2017 7:01 pm
G/Day well bit more done made the dash board it is Mahogany and Silver Ash trim .....John
John R
Re: Aussie Gentry
Postby John R » Fri Feb 24, 2017 7:05 pm
G/Day well nice warm weather so i got 4 coats of primer on this is Luxepoxy white primer now wait the 7 day for full cure then sand ready for the Luxathane Blue......John
John R
Re: Aussie Gentry
Postby John R » Mon Mar 13, 2017 5:55 pm
G/Day well i have rolled 4 coats of Luxathane (water raceway blue) wait till hard then sand and fair then i will spray the last 2 coats, also finished the dash and fitted the steering wheel......John
John R
Re: Aussie Gentry
Postby John R » Mon Mar 13, 2017 5:57 pm
Users browsing this forum: Bing [Bot] and 18 guests
