Porpoising
BlueRidgeBoater
Porpoising
Post by BlueRidgeBoater » Tue May 12, 2015 6:51 am
I finished my 14' Power Skiff and launched it last weekend with a 15hp 4-stroke. Perhaps not unexpectedly, it has horrible bow rise with only one rider and bad porpoising. (When it was just me in the boat, and at low speeds, but brother in law nicknamed the boat the SS Viagra). I've got the motor trimmed in. I put two 30 lb weights in the front, and that helped, but I still can't go more than mid throttle on a smooth lake without being like Flipper. I hate to have to add a bunch of extra weight to improve ride quality because of the room it will take up (but will if I need to). I ordered some Smart Tabs to install hoping that will help. Has anyone used these? If so, what is your reaction to the product?
Re: Porpoising
Post by chugalug » Tue May 12, 2015 7:05 am
:D Haven't used those.used to have a plastic whale-tail on motor .really liked those. made the motor kinda ugly and was a pain to hand clear weeds but seemed to help putting boat on plane faster and at a slower speed
BlueRidgeBoater
Re: Porpoising
Post by BlueRidgeBoater » Tue May 12, 2015 8:53 am
I looked at the whale tails, but the only ones I saw that would fit a 15 hp motor bolt through the cavitation plate and that would void my warranty with Suzuki. I've also heard that trim tabs do a better job of adding lateral stability.
fergal butler
Re: Porpoising
Post by fergal butler » Tue May 12, 2015 10:33 am
I made up some trim tabs for my boat and they worked a treat and stopped the porpoising :D I never did like the idea of drilling holes in an outboard to fit fins I feel if they were that good then outboards would come with them :)
Soloboat
Re: Porpoising
Post by Soloboat » Tue May 12, 2015 11:32 am
Maybe the motor is trimmed in too far. Once you are on plane trim motor out until it starts to cavitate then trim back in to the sweet spot.
Re: Porpoising
Post by gdcarpenter » Tue May 12, 2015 1:52 pm
Before spending $$$ you might try placing some shims between the engine and the transom to effectively trim the engine in a bit more. I believe this has done been done by one or more builders on this forum.
BlueRidgeBoater
Re: Porpoising
Post by BlueRidgeBoater » Tue May 12, 2015 4:14 pm
I'm confused on the issue of trim. If I'm reading the posts right, Soloboat you are saying I need to trim out, and gdcarpenter you are saying I need to trim in more. My instinct is that I need to trim in more because I don't have porpoising when someone sits in the front of the boat, so it seems to me I need to get the bow down more. A guy at Boater's World told me the other day, though, that I need to trim up to put more pressure on the stern. Having heard it both ways, I'm a bit confused. I guess I will experiment with more trim, but I think I did that already and still had bad porpoising. I'll probably install the trim tabs anyway since they are on the way and lots of people say it helps with porpoising. Looks like an easy install also.
BlueRidgeBoater
Re: Porpoising
Post by BlueRidgeBoater » Tue May 12, 2015 4:16 pm
Fergal Butler: Sweet looking ride. Maybe down the road I'll try something that ambitious.
Soloboat
Re: Porpoising
Post by Soloboat » Tue May 12, 2015 4:42 pm
There are several youtube videos on how to trim properly Give a look, experiment before getting too drastic :) After 3 years I am still fine tuning my boat and honing my skills. The day I launched my boat was only the second time I was at the controls of a power boat.
Re: Porpoising
Post by Bill Edmundson » Tue May 12, 2015 5:34 pm
The first thing is to take a straight edge and make sure the bottom is flat the last several frames.
BlueRidgeBoater
Re: Porpoising
Post by BlueRidgeBoater » Tue May 12, 2015 5:46 pm
I'm pretty sure it's flat, but will check it.
Re: Porpoising
Post by gdcarpenter » Wed May 13, 2015 6:19 pm
My apologies, must have had a 'senior moment' - yes you need to trim the bottom of the engine out to help it 'push' the bow down. If you have a standard tilt pin move it rearward a hole or two and experiment.
Re: Porpoising
Post by chugalug » Wed May 13, 2015 7:00 pm
:D Actually, if you don't have weight in front, you should trim motor in .We had that problem at the resort-Dad had gotten a 4-stroke Tohotsu 25 ,A lot of weight for rear of 16 ft. lund with a single person. was a dog until we extended the fuel hose and put fuel tank up front and put lower pitch prop on.Now runs fine.When I had my 50 Johnson I even raised motor up 3/4 inch-made a lot of spray on back ,however gained 3 or 4 mph.
cusoak
Re: Porpoising
Post by cusoak » Thu May 14, 2015 5:03 am
Not sure how much your boat weights, but if you are in the back using a tiller handle, you weight and the motor weight might be enough that that 15 hp wont get the boat up on plane.
Does it get up on plane.
Jeff
BlueRidgeBoater
Re: Porpoising
Post by BlueRidgeBoater » Thu May 14, 2015 5:52 am
The boat doesn't have any trouble getting on plane, it's just that without a fair amount of weight in the front when the engine is more than 1/2 throttle it porpoises badly. I got some Smart Tab SX tabs in the mail yesterday. Going to install them and see if that helps. If not, I'll probably get 50-100 lbs of lead weight and put it up front.
