Varnish over epoxy
SamsBoat
Varnish over epoxy
Postby SamsBoat » Thu Jun 23, 2016 6:30 pm
I'm looking for some recommendations for varnish over the epoxy fiberglass on outside of the boat. What is working well and not so well? We are using the Silver Tip Epoxy. Also any recommendation for a good sealer for the interior of the boat?
Re: Varnish over epoxy
Postby chugalug » Fri Jun 24, 2016 6:20 am
I tried Epifanes clear varnish (thinned and one spot straight) over a 3 week epoxy cure-would not set up right.still tacky after sitting in warm boathouse for three weeks more.I got disgusted and used water-based Zip Strip to remove varnish and used primer and paint instead.Should have tried a 2 part polyurethane instead(Interlux)For sealer on inside of hull,I used CPES I got from the Rot Doctor Place.Fumy stuff-use respirater.Also used little hand operated spray bottles( cheapie ones from hardware store) adjusted so more product came out then air and sprayed into cracks and crannies unreachable from brush.
Postby gdcarpenter » Fri Jun 24, 2016 11:08 am
I used Petit Flagship Varnish over the epoxy inside and out. Satin on the inside, gloss on the outside.
galamb
Postby galamb » Fri Jun 24, 2016 6:10 pm
I used Epifanes rapid coat and had good results - epoxy was cured for longer than a month which may have made a difference. I used that as my build coats and then topped with Interlux Schooner (I'm not brand loyal).
You are also asking about an interior sealer - if you are talking "below decks", I went with Interlux "Interprotect 2000" after asking on this site a few years back when I was "looking". It's meant as a hull primer but works awesome down in the bilge area to protect against all manner of "cooties".
Graham
steveh41
Postby steveh41 » Sat Jun 25, 2016 9:39 am
If you're using System 3 Silver Tip epoxy underneath, this is the varnish I would recommend:
https://systemthree.com/products/marine-spar-varnish
Gayle Brantuk
Postby Gayle Brantuk » Mon Jun 27, 2016 10:23 am
You can also get System Three products from Glen-L:
http://www.boatdesigns.com/System-Three-Spar-Urethane-Varnish/productinfo/S3-598/
We appreciate your business!
SamsBoat
Postby SamsBoat » Wed Jul 06, 2016 10:24 am
Thank you everyone. I appreciate the advice.
Postby Bill Edmundson » Wed Jul 06, 2016 11:54 am
I'm supposed to get Pettit EasyPoxy High Build Varnish tomorrow. I'll report. I've had good luck with this line of paint.
Ronb172
Postby Ronb172 » Wed Jul 06, 2016 1:52 pm
I'm using Pettit Z Spar Captain's 1015 and I'm really liking it. I did let the epoxy cure for at least 2 weeks. In the heat we're having the 1015 is dry ib a few hours.
Building my third SUP.
Started the Topper build.
BarnacleMike
Postby BarnacleMike » Fri Jul 08, 2016 11:21 am
I'm using Petit Z-Spar Captain's Varnish over System Three Silvertip & fiberglass, and I've been quite happy with it.
-Michael
Currently building a Zip
Postby Bill Edmundson » Thu Jul 14, 2016 6:58 am
I did a test of Pettit EasyPoxy High Build Varnish over well cured MAS yesterday. Works Great! It was dry to touch in 4 hours. No thinning required and very little smell.
Ronb172
Postby Ronb172 » Tue Aug 16, 2016 8:06 pm
I was just wondering what the epoxy looks like when too much UV gets to it and what we should look for? Does the epoxy begin to turn a darker brown or begin to bubble?
Postby gdcarpenter » Wed Aug 17, 2016 3:44 am
With too much UV exposure the epoxy finish turns whitish, often blotchy areas of the whitish color.
Ronb172
Postby Ronb172 » Thu Aug 18, 2016 9:20 am
That's good to know GD, thanks.
steves
Postby steves » Sat Apr 15, 2017 5:22 am
is there such a thing as a varnish filler primer?
Return to “Epoxy”
