Installing strakes after or before fiberglassing?
galamb
Re: Installing strakes after or before fiberglassing?
Post by galamb »
I installed mine after.
My reasoning was as follows.
First, it made laying down the cloth a whole lot easier - nothing to work around, cut around etc.
Second, if the strakes ever get damaged, rubbed, hard grounding etc they could be replaced or repaired (ok, a bit to a lot of work) without messing with the integrity of the (sealed) hull.
Graham
Peter
You might consider solid vinyl (PVC) for the strakes. you can get it at the big box store.
galamb
Post by galamb »
Great tip Bill on the PVC - never would have thought. Used the PVC (boards) to trim out all my house windows when I replaced them - machined great and never have to mess with it (paint etc) ever again.
Peter - I installed them (epoxied to the hull which was covered in cloth/epoxy). Then I just went over them with three coats of un-thickened epoxy (no cloth of additives) - basically just "painted" them with three coats. Then painted over everything (Interlux VC Performance epoxy - wanted a white bottom and didn't really care about true anti-fouling - run in fresh water and trailer the boat).
They are holding up well (fifth season now), but I haven't grounded the boat and it lives on a trailer in between trips.
Graham
Return to “Fiberglass”
