Dave Grason wrote:eamelink wrote: If so, I presume I should stain the wood after glueing the mahogany planks on the deck, and before applying the oak strips?
Yes, that's the way I would do it. But you may (or you may not) want to tone the oak down a little. When I worked in the flooring biz for so many years, virtually all of the red oak and sometimes the white oak would look harsh and very bright (too bright really) if we didn't stain it somewhat. So when a customer wanted a "natural" finish, we used Minwax Natural. It's more of a linseed oil based stain and doesn't actually have any coloring agent in it. But it gave the oak a nice honey colored tone to it and always looked beautiful. But you should take some scraps of oak and experiment with different combinations. Better yet, do what I do and take one big peice of oak scrap and stain several areas on the same board so that you can see comparisons side by side.
I'm going to find myself a nice piece of oak tomorrow, so I'll definately try some staining. However I don't have stains here, so tough trying...
But then, that throws yet another wrench in the works. If you use an oil based stain, you'll need to sand over it enough to scuff it one time if you plan on fiberglassing over with epoxy and cloth. Otherwise there will be adhesion problems. This isn't necessary with water based stains but in my opinion, water based stains lack the warmth and glow of a good oil based stain. They're good but they're not GREAT! But that's just me.
The store where I buy my epoxy has this stuff :
Naast dekkende pigmentpasta’s bestaan er ook transparante epoxy-pigmentpasta’s in hout tinten. Gemengd door epoxy kan hiermee op hout een beitseffect worden verkregen...(cut)... Leverbaar in de kleuren eiken, teak en mahonie. Van deze pigmentpasta behoeft slechts 1 tot 3% te worden bijgemengd.
That means something like:
We also have transparent epoxy-additives in wood colours. Mixed with epoxy you can get a stain-effect.... (cut)... Available colours are oak, teak and mahogany. Only 1 to 3% is needed.
I'll go there tomorrow and see if they have examples of it. The good things is that's definately compatible with epoxy
On my boat, I do not plan on fiberglassing the deck.
Well, just today I was reconsidering my fiberglassing thoughts. I'm not sure if it's needed, and I'm also worried about the edges; what to do with them?? I might skip the fiber as well. After all, I'll kick anybody off the boat who dares to stand on my nead deck
I'll be using an oil based stain and then going over that with 2-3 coats of CPES from Smith & Co. Then I'm going to use Smith & Co's "5 Year Clear" as a varnish. Personally, when using a deck cloth over bright finished mahogany, I feel that some of the grain definition is lost and appears slightly cloudy. It looks good in photos or from a distance, but when you get really up close, you can see the difference. The CPES will lock in the stain, is perfectly compatible with oil based stains and will give an excellent base for varnish. The CPES will NOT dissolve the stain either, so there is no worry about getting a good stain color and coverage and then messing it up with the CPES. Finally, the CPES will give the wood a level of rot restistance unheard of in the past. This boat will no doubt last for 50 years or more with care.
The shop also has "Poly Pox Injecteer". That's a very thin epoxy as well, also meant for being sucked into the wood (it's usually used as a primer before normal epoxy). I'll ask them if it's compatible with oil-based stains.
Wow, that's a BRIGHT red! That's the kind of red you don't want to wake up to with a hangover, they'll certainly see you coming for miles!
Remind me what kind of paint you used, and how you applied it?
I know it's very red, but the "bordeau-red" was sort of brown, and ugly. So I took the risk, while I was driving home I thought I'd made a mistake taking this paint, but after applying I loved it
It's a two component polyurethane coat, called "DD lak" (DD coat), here
http://www.polyservice.nl/ <-- The shop, they only sell polyester, epoxy, polyurethane, glassfibres and any needed to apply that stuff
And it's just a 20 minutes drive
