Filling pin holes left by staple legs
Tony Hain
Post by Tony Hain »
So there must be an easy way to fill the pin holes left by staple legs in the final layer. I have applied that many coats of epoxy and sanded off that I have lost count and still there a a lot of dimples in the final mahogany layer. Below the water line it did not matter as I painted that section and used a filler, but above the waterline I have not stained so was worried about trying to use a filler in case the colour did not match. I have tried a syringe but as the surfaces are vertical the epoxy just ran and I still ended up with dimples.
Tony Hain
Re: Filling pin holes left by staple legs
Post by DrBryanJ »
A lot of builder use famowood mahogany. I have been doing that myself. I don't know how the color will match, but several posts have said the shade is pretty good. The can will dry out very quickly, so take out just what you need and reseal.
Tony
My solution is drive faster! They're hard to see at 60 Km per hour.
Tony Hain
Post by Tony Hain »
Probably a filler before I started epoxying would have been the go but now I have a few layers on I am not sure that will work. Bill is probably right and I am stressing about nothing. Anyway I have a couple of layers of clear coat to go yet which could solve the problem.
Tony Hain
WayWard
Post by WayWard »
Tony Hain wrote:Probably a filler before I started epoxying would have been the go but now I have a few layers on I am not sure that will work. Bill is probably right and I am stressing about nothing. Anyway I have a couple of layers of clear coat to go yet which could solve the problem.
Yeah I'd say that ship has sailed. You may be able to sand them out after a couple extra coats of epoxy
Return to “Epoxy”
