Tuffy Build
Evan
Tuffy Build
Post by Evan »
Started today.
I got the plans in the spring, I was hoping to start a little sooner but things came up and I have less $$$ than I think I do.
Picked up some supplies between then and now, they sure don't give that 3/4 marine plywood away!
Managed to get some 14+ foot ash so no worry about joints, I had thought about going with oak but at 1.25 a BF ash wins.
Today I cut the gussets put and got the lumber ready for the wider pieces of the first 2 frames. It will take a day or so for the glue up as I apparently do not have enough clamps.
Not much time in but it was a start.
Re: Tuffy Build
Sounds like a good start.
Now, repeat as necessary. :D
Not sure what's available in Canada, but I picked up an arm load of $0.99 spring clamps at home depot. They've been handy to have around.
Re: Tuffy Build
Harbor Freight has slide clamps for $3.00 US that are perfect for this type of work. You can buy 10 of them at a time for a little over 30 dollars.
BayouBengal
Re: Tuffy Build
Post by BayouBengal »
I'll really look forward to following your build. The Tuffy is not a boat that has been built by many forum users; but I don't understand why. It's got great lines and is a nice medium size boat that would be very useful and fun.
I myself believe that I'm retired from any future power boat building (never say never). However, if I were to build another I think the Tuffy would be it because of a combination of liking the way the boat looks and happening to have in my possession a gold 1957 Johnson Javelin outboard that would be a perfect match for it. But for the time being, I'll just have to be happy living vicariously through your build.
Be sure and post lots of pictures!
Evan
Re: Tuffy Build
Post by Evan »
Not sure why there are not many, I think it is a good looking boat.
We don't have harbour freight but Canadian Tire has some good sales on clamps here and there. I might have to take a run to a Home Depot to get wood for the form anyway, the places near me keep theirs outside.
I still have to get proper nails/screws, I hope to order those next week, that will give me time to glue these parts together and hopefully draw the layout.
Hopefully I can put something decent together.
Evan
Re: Tuffy Build
Post by Evan »
I got the first frame drawn out and cut out the side pieces, they fit into the drawing so I guess that is a good sign.
I don't have my fasteners yet, hopefully by the time I get them I will have the other frame pieces close to ready so it will just be a matter of drawing them out to put them together.
BayouBengal
Re: Tuffy Build
It's always exciting cutting them first pieces of wood and seeing the frames in real size. Looks like you're off to a great start!
FarmBoat
Re: Tuffy Build
Post by FarmBoat »
Greetings All. I saw where someone said they didn't see many Tuffy's being built and had to reply.
I started two years ago, cut out all the hull pieces, fine tuned them and left the project upstairs in the garage. I meant to get back to it, but what got me back now is the story about the guy that took 17 years building a Lamborghini in his basement that I read. That's all it took. Retiring from the Army National Guard this year left a little more free time in my schedule too.
Anyway...here's where I'm at with no plans on slowing down. However, winter is coming; have to love Maine. I do have a monitor to get me through the outer plywood stage coming up. There's a temporary transom in the picture. Need to grab another sheet of ply soon.
Permanently attaching the stem as I speak...gotta run.
Later,
Jay
So far...to go
So far...to go
BayouBengal
Re: Tuffy Build
Welcome back to building, Jay! Looks like you're off to a good start.
Evan
Re: Tuffy Build
Post by Evan »
I am happy to see another one, especially one that is ahead of me.
I ended up getting my fasteners and got a frame put together, I was happy with the way it turned out. Unfortunately after that I came down with Lyme Disease so I have not been doing anything (at all) for a number of days now.
Hopefully I will get a bit of time in but hunting season is coming up which wont be ideal for boat building.
Evan
Re: Tuffy Build
Post by Evan »
Seems I am poor about documenting. I don't have much time in, most of it is cutting a piece or two as I have a minute.
The form is built, frames are attached to it, one and two are level as they are supposed to be.
The transom and stem are cut out, I clamped the stem in place, it seems to line up.
The keel is there but I still have to laminate the piece of ply to it, the plans say 1 1/4. After the board was cleaned up I am just under an inch.
So far things seem to be going ok, I guess it could be building to realizing a big mistake.
I did break off the first one of those bronze screws, after that I started driving a screw of the same size prior.
Re: Tuffy Build
Looks like you're making good progress. Keep it up.
Evan
Re: Tuffy Build
Post by Evan »
Slowly forward. I have the chine glued and screwed, except at the transom. I used boiling water and towels to help with the bend, nothing broke so I guess it worked. I did a few measurement checks just to make sure.
The cutouts for the chine went OK. The first one needed some fine tuning but the second was easier.
If I have a few drinks and try really hard I think I can see a boatish form.
It is still a long way off but I am planning to glass the bottom, is there any recommendation for the weight I should use?
Re: Tuffy Build
I used 6oz cloth. Haven't launched yet so I can't speak to ultimate durability but It didn't take a ton of epoxy to fill the weave. You're doing a great job on your boat! Tuffy is a cool design.
BarnacleMike
Re: Tuffy Build
Post by BarnacleMike »
I used 6oz on my Utility, and I've been happy with it. In retrospect, I'd use 4oz on any bright work such as the deck or transom, etc.
