Building a Squirt
CraigBBP
Building a Squirt
Post by CraigBBP » Fri Aug 11, 2017 12:43 pm
Hi all,
Waiting on plans to begin the journey of building the Squirt.
Any initial advice that I should know before digging in?
Thanks
Re: Building a Squirt
Post by hoodman » Fri Aug 11, 2017 5:28 pm
Read "Boatbuilding with Plywood" if you haven't already.
Post by Hercdrvr » Fri Aug 11, 2017 8:37 pm
Yep, read the book like Matt "Hoodman" said and stretch the boat the full %10. Send pics of your progress.
Post by PeterG » Fri Aug 11, 2017 8:49 pm
Definitely get the Glen L book, and read any other boat building book you can find... All are helpful.
And remember, the only bad questions are the ones that don't get asked. We're all here to help. Post pictures of your progress and remember to have fun!
Post by Bill Edmundson » Sat Aug 12, 2017 5:11 am
Craig
Better to ask a bad question than to fix screw-ups!
We'll help with both.
Post by JimmY » Sat Aug 12, 2017 5:24 am
Plan ahead. Get a idea of how you're going to finish things, as that might impact your early work. The BOM listed will get you to the flip, so you will need more epoxy and supplies than you think, so don't worry about ordering extras.
Keep working on it, even if it is just sanding for 15 minutes here and there. Finally, have fun and take your time. Hopefully, you'll have the boat much longer than it takes to build, so spending some extra time in the shop to build it right will worth it when you're finally on the water.
Good luck,
