pvc drain tubes
svenole
pvc drain tubes
Postby svenole » Fri Sep 08, 2017 10:11 am
I'm using pvc pipe for my drain tubes ...can I use epoxy to seal and glue them in?
Re: pvc drain tubes
Postby hoodman » Sat Sep 09, 2017 7:48 am
I'm doubting that epoxy will stick to PVC. It doesn't bond well to most plastics. Maybe 3M 4200 is a better choice?
Adrock1
Re: pvc drain tubes
Postby Adrock1 » Wed Sep 13, 2017 4:41 am
I've seen people do it with epoxy but only after roughing up the epoxy with a coarse grit sandpaper paper to ensure a good mechanical bond. Even with a good mechanical bond though, im not certain it would prevent all water intrusion.
Mr Hot Rod
Re: pvc drain tubes
Postby Mr Hot Rod » Wed Sep 13, 2017 11:05 pm
Epoxies don't adhere well to many plastics because these surfaces are too smooth to allow a mechanical bond. One of the Gougeon Brothers' User Guides recommends cleaning the pipe with the correct cleaner for that type of pipe and applying a thin coating of ABS/PVC cement. Once the cement has completely dried, apply the epoxy over it.
See Bonding Plastics, page 13 :
____________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
Glen-L Hot Rod build thread
Glen-L Boat Video Directory
Users browsing this forum: No registered users and 18 guests
