Trasom Drains: Yea or Nay?
Re: Trasom Drains: Yea or Nay?
Post by Roberta » Thu Oct 05, 2017 6:15 am
Good idea to have extra plugs. :lol: :lol: :lol:
Roberta :lol: :lol: :lol: :lol:
Mark-NJ
Post by Mark-NJ » Thu Oct 05, 2017 9:44 am
I like the idea of a dishing washer forming the flair! Thanks.
One question: how long should I cut the tube so the flaring is sufficient? 1/4" longer than the transom thickness? More? Less?
Post by hoodman » Thu Oct 05, 2017 9:49 am
Do you even have to flare the tube or can you just cut it to be flush?
Post by Bill Edmundson » Thu Oct 05, 2017 10:18 am
I cut mine about 1/8" long with a tubing cutter.
Mark-NJ
Post by Mark-NJ » Thu Oct 05, 2017 11:36 am
hoodman wrote:Do you even have to flare the tube or can you just cut it to be flush?
Now THAT'S a thought worth pondering!
If the tube is "in there & not going anywhere" [i.e. glued in with epoxy or 5200, etc.), then why flare at all? If anything, the space under the flare is just a place to trap moisture, dirt, etc.
Any downside to a flush cut?
Post by hoodman » Thu Oct 05, 2017 12:02 pm
It's already flared on one side correct? Presumably the outboard side. The pressure of the water from the boat floating pushes it in.
Mark-NJ
Post by Mark-NJ » Thu Oct 05, 2017 1:07 pm
Yes....pre-flaired on one end.
That said, they're only about 6" below the waterline, so the water pressure is only about 0.22 psi over ambient....which I would suspect does very little to keep it in place.
Mark-NJ
Post by Mark-NJ » Sat Oct 07, 2017 3:03 pm
I drilled some 1" holes in scrap Sapele and made some test fits. Practice makes perfect, right?
I measured, verified & marked "the spot" on the transom. Then I measured again.
I put a sharp 1" forstner bit in my drill.
I sat behind the boat on the ground, got good & comfy.
....and I just couldn't do it. Call it "risk vs. reward", but I'm just not convinced this isn't an open door to leaks & rot, no matter how careful I am.
BarnacleMike
Post by BarnacleMike » Sat Oct 07, 2017 3:49 pm
I decided against them, too... even on a small boat like the Utility. As I came to see it, the potential problems far outweighed a little convenience.
If you decide against them, I'd recommend keeping the bilge area accessible (especially at the transom) so that you can sponge out whatever the bilge pumps don't get.
Also, don't forget your crosswise limbers under the battens. Otherwise, you'll wind up with water trapped on one side that you'll have to mop out somehow. (Another reason to install dual bilge pumps imho)
-Michael
Post by Roberta » Sat Oct 07, 2017 4:04 pm
Your boat being more open will be easier to monitor and clean out. More enclosed boats would benefit more with the drains. But a proper installation would also be fine.
BillW
Post by BillW » Sat Oct 07, 2017 4:15 pm
I think you made the right decision.
Many wood boats, and fiberglass boats with wood core transoms, have rot around the drain plug, whether the owner knows it, or not.
Probably, nearly all older boats have that issue.
HotSaws
Post by HotSaws » Sun Oct 08, 2017 5:35 pm
I too agonized over this decision with my Zip build, but ended up nay. There are pros/cons either way. For me the biggest reason I didn't was that in other boats I have owned the hole wasn't quite on the bottom, so I had to dry the boat out with a sponge/towel anyway. I did not have confidence/courage that I could get two of them drilled well enough for the tube to fit well without interfering with screws/keel/etc and still be on the bottom. Finally, I decided I could always drill one later if I changed my mind.
Had I went with the hole, it would have been really nice to have been able to hose out the epoxy dust after sanding the insides during the build! Instead I had to use the shop vac and a bucket/towel.
Post by Hercdrvr » Mon Oct 09, 2017 3:15 am
Kind of depends on how you use your boat, for me drains are needed. Between kids and dog dragging water up the swim ladder, spray over the hood or hosing her down at the car wash, I need drains to get all that water out. I’m lazy too, sucking out the water with a shop-Vac works great but I’m too tired for that after being on the water all day.
ToddM
Post by ToddM » Mon Oct 09, 2017 10:56 am
Mark-NJ wrote:I like the idea of a dishing washer forming the flair! Thanks.
How does a dishwasher form a flair?
:lol: :lol: :lol:
Post by Roberta » Mon Oct 09, 2017 12:18 pm
You put it on potscrubber mode.
Roberta :mrgreen:
