Glen-L Carries Epoxies for Your Project
Gayle Brantuk
Post by Gayle Brantuk »
For over 40 years, Glen-L has provided our proprietary epoxy specifically for the amateur boat builder: our "Poxy-Shield" multi-purpose laminating resin and "Poxy Grip" structural adhesive. We also stock System Three SilverTip epoxies and products as well. We appreciate your business so we can continue to provide this Forum and all the other resources available at Glen-L. You can order epoxy via our online store
Conrad
Re: Glen-L Carries Epoxies for Your Project
Post by Conrad »
Forgive my ignorance. I used poxy grip on all the building joints or mating areas. I have poxy shield to encapsulate the hull. Do I need to thicken the poxy shield when putting on the cloth? Do I need to encapsulate prior to laying the cloth on?
John
Keep your lines tight!
Conrad
Poxy Shield should not be thickened when using as a sealer or fiberglassing. A seal coat prior to fiberglassing is a good idea to prevent the wood from sucking up the resin during the initial wetout to prevent starving of the cloth, which causes dry spots. Apply a seal coat and lay the cloth down on it while the resin is in the "green stage". This occurs after a few hours when the resin is slightly tacky and not fluid. Should be done within 24 hours.
I put the sealcoat on in the early morning and lay up the cloth in the late afternoon.
Conrad
Post by Conrad »
Thanks!
Roberta wrote:
Sun Nov 24, 2019 6:45 am
Conrad
Return to “Epoxy”
