Still no jet builds?
cepjr
Post by cepjr »
I'm still working on mine!
JasonG
Re: Still no jet builds?
Post by JasonG »
Your Dyno jet looks great! I have a build thread on here about the one I started but life got in the way and I still haven't finished. Hurricane Michael pretty much put me out of the boat building hobby as the winds blew down the barn were I was working on it. The boat wasn't harmed but it's definitely on the back burner.
Now that I know you're building one, I will follow this thread closely. I'm looking forward to seeing you get it done!
cepjr
Post by cepjr »
Sorry to hear about your storm damage! I found your thread you where far along to put it on the back burner mine is like an addiction I gotta just keep going! What where you planing for a engine? I used part of the ski hull in mine just made mother mounts easy. I had to change the pitch of the ski hull a few degrees I'll send some pics maybe we can JumpStart your build!
cepjr
Post by cepjr »
I almost forgot my helper
JasonG
Post by JasonG »
I'm using an old Tigershark 640 as the donor ski. The engine was made by Suzuki and the one in my ski was toasted. I've got a new used one, in fact, I have all the parts to finish it, just other properties right now.
Your build looks great, keep the pics coming! You never know, I might jump back on it.
Too bad our helpers can't pick up a sanding block! :lol:
cepjr
Post by cepjr »
My helper doesn't sand she just sleeps! She lost her hearing so now the power tools don't bother her! I went with a polaris 750 triple Donner the price was right just did the top end so it should be good to go . got a few more planks cut and fit tonight pics soon :)
cepjr
Post by cepjr »
]Got the deck on now encapsulation!
JasonG
Post by JasonG »
Awesome!
Looking real good!
Shane_B
Post by Shane_B »
That looks great, I just picked up my jet ski a few months ago for the Squirt I'm building. I got the ski for free so I didn't bother even looking at it till I got it home. I cleaned the carbs put a new battery in it and it fired right up. Display said it only has 79 hours on it! This is a Polaris SLTX 1050 90s model, it might be too big for my boat but I plan on extending the length and adding a dove tail on the back deck like the torpedo. My plan is to do exactly what your doing and use as much of the bottom of the ski hull as I can.
cepjr
Post by cepjr »
Hello Shane b that's sounds like plenty of engine for a squirt!! I thought I over did it! On The jet ski hull piece I used the fee angle wasn't perfect so I sliced the motor mount portion most of the way through and changed it then filled it solid with epoxy! Lot of work but it cut down on fairing. Send pics I gotta see this! :D
cepjr
Post by cepjr »
Jason G get your helper and get going!!!!!! :D and thanks I haven't done much in two weeks work gets in the way :o :(
Captain
Post by Captain »
Awesome work guys glad to hear other people are using Polaris powered motors. I started a topic on my build, a Bullet powered by a Polaris 1200 but that’s as far as I have made it. Life has kept me busy with our second child, work and all my other projects I have. Keep up the good work and hopefully I will get mine built one day.
Kyle
Jet Bullet 1200 Triple 2 Stroke Build
If You Want To Go Fast You Have To Mix Oil And Gas
cepjr
Post by cepjr »
Finally got paint on the bottom!!! Work is wreck in progress!
cepjr
Post by cepjr »
cepjr
Post by cepjr »
Return to “Jet Ski Power”
