Jet ski speed...
Jet ski speed...
I am beginning the initial stages of my Flying Saucer build. While planning to use a jet ski engine, I will have to modify the cockpit position. However I am looking for some info on how the boat planes, and what type of speed is expected or resulted from putting a 650 in a 12'-14'boat? Depedning on how prior builds have planed I would like to adjust accordingly. I am looking for 25mph+. In anyones opinion is this possible?
- steve crawford
I think 25mph is no problem. With the bolt -ons you can do to these 650's.
Intake grates-impellers-bigger carbs-high compresion heads-exhaust.
A lot of guys on http://www.pwctoday.com/ that can answer all kinds of questions.
For cross referencing Kawasaki parts to see what will interchange go to
http://www.kawasaki.com/DefaultFrame.as ... EHICLE.ASP
I found the same drive shaft is used from 1989-1999 on 650-750-900 2person skis. But the 650 stand up also has the same spline and I think the 550SX does also .
The 550 js does not .And if I had it to do over again I wouldn't get another 550 especialy the js. The splines don't match up with annything. So if you want a shorter drive shaft you are out of luck.
And the 550sx pump impeller is about 1/4'' bigger in dia. than the older JS
so watch out when geting parts. They started making the 550 sx in 89 or 90.
And the seado jet pumps have a plastic or teflon wear ring in the pump housing. Unlike the stainless steel other manuf. use.
THE FRAUD WILL NOT GO AWAY..9-11 WAS AN INSIDE JOB...
http://www.drjudywood.com/
http://s147.photobucket.com/albums/r302 ... rd_photos/
https://www.flickr.com/photos/mo_kayaks/sets/
