Hatch on a Squirt
RoyH
Hatch on a Squirt
Post by RoyH »
I'm about to start with the desck-beams on my squirt, and want to have a hatch on the aft deck.
I'm planning on using mini boot hinges at the rear like Graham Knight did on his boat.
On the front of the hatch-frame, how do I build this so that it will open without bumping into the forward deck-beam?
Must I cut the forward hatch-beam at an angel or is there a better way?
I don't want a huge gap between the deck-beam and the hatch.
I'm just a starteled bunny in the headlights of life..
Roy,
You can put an angle on the hatch frame piece or if the depth of the frame is not that much do what I did. Take a belt sander and grind the lower edge until it swings free.
RoyH
Post by RoyH »
Thanks Bill, I will measure and deside when the deck beams are installed.
