ZIP & Mercury Mark 35A - Steering
I've been absent for a bit as we relocated from CT to NC.
Currently restoring Mercury Mark 35A circa 1959 for the ZIP I will build next.
Mark 35A tilt tube is 1/2" ID - will a teleflex steering system work with this tilt tube?
I'm sure I found somewhere here before that someone had the same motor and had the motor castings bored out to accept a larger diameter tilt tube, can't find that post now.
Any and all help appreciated.
Garfield
Garfield
Re: ZIP & Mercury Mark 35A - Steering
The teleflex steering system will not work with the older motors but all you have to do is switch the clamp brackets and tube from a 1964 or later motor.
Hope this helps
Hope this helps
I had a Mark 35A that someone made an adapter to use Teleflex cable.
They made two plates about 3" or so with two holes drilled in each plate,one the size of the tilt tube on the motor,and one the size of a newer tilt tube.Make the brackets just long enough to position the new tube in front of the clamp brackets.
Take the nuts off the old tilt tube and slide the plates on and refasten the nuts, positioning the new tilt tube in front of the clamp brackets with nuts on both ends.
works fine and you can still tilt the motor.
There are also brackets available that allow you to attach Teleflex cables.
This company has some that mount on the transom....click on steering:
http://www.trmarine.com/cat.html
Thanks for the input.
Garfield, the post you couldn't find may have been mine. I adapted a Teleflex Safety QC system to our 1956 Merc Mark 55, which has the early, 1/2" ID tilt tube. The thread on these early tubes is 3/4--16 (UNF), while the Safety QC system cable requires 5/8" ID and a 7/8--14 thread. I have access to a lathe, so I obtained a section of #304 stainless bushing stock that conveniently had the correct dimensions (especially the .630" ID), making it a simple job of cutting the required threads. I did have to purchase a large chucking reamer to open up the clamps. If you can't find a post-'64 clamp assembly, you might take the whole mess to a local machine shop. I found the material for my tilt tube at Onlinemetals.com. Hope this helps.
Mark Shipley
Built the "Zip"
Mark Shipley
Built the "Zip"
Thank you Mr. Shipley! Maybe I don't have 'old timers' yet.
If it means anything I plan on building a ZIP once I get done with the Mark 35A, and for what it's worth I have the photo album of your ZIP build on my most visited bookmark bar.
Glad you got back to me, waiting for the paint that's on it's way and will now need to hustle to get the tilt tube remedied before painting.
Thanks to all for your suggestions, the larger tube install seems to be the most, shall we say, 'eloquent'.
Just discovered that I can get a ready made stainless steel tilt tube, one less processing step.
Hi Mark,Moeregaard wrote: ↑Tue Oct 13, 2009 12:54 pmGarfield, the post you couldn't find may have been mine. I adapted a Teleflex Safety QC system to our 1956 Merc Mark 55, which has the early, 1/2" ID tilt tube. The thread on these early tubes is 3/4--16 (UNF), while the Safety QC system cable requires 5/8" ID and a 7/8--14 thread. I have access to a lathe, so I obtained a section of #304 stainless bushing stock that conveniently had kthe correct dimensions (especially the .630" ID), making it a simple job of cutting the required threads. I did have to purchase a large chucking reamer to open up the clamps. If you can't find a post-'64 clamp assembly, you might take the whole mess to a local machine shop. I found the material for my tilt tube at Onlinemetals.com. Hope this helps.
Mark Shipley
Built the "Zip"
My search of the web brought me to this thread and subsequently to your post.
I am about to follow what you did with your Mark 55, however mine is a Mark 35a.
It’s all clear what I need to do except when it comes to the tie rod. May I enquire what you used?
Rgds,
Scott W
* tie rod = drag link
Hi, I bought a SS tilt tube of the right diameter and thread and drilled and reamed larger diameter holes in my Mark 35A and a Mark55. I fabricated my own bracket to connect the link to the engine, other options are available.
Thanks very much for the info gdc. I have just bought a 7/8 stainless tilt tube and plan to have the clamps and saddle bracket machined to the correct diameter.
Wondering how you went about doing yours? Does it require disassembly of the motor to machine these parts...?
Rgds,
Scott
Rgds,
Scott
Wow--the length of this thread must be some kind of record! I believe I left one question unanswered. For the steering link I used a length of stainless-steel tubing, 3/8" OD X .063" wall. I tapped it internally for a 5/16" X 24 thread and installed a rod end on it. All of the materials were Swagelok-brand and purchased from McMaster-Carr. There's a photo of it in the Customer Photos page. Over ten years since launch and nothing has failed.
-Mark Shipley
One Zip, two Can-Yaks, what's next?
-Mark Shipley
Thanks Mark for the info on the steering link. In your original post some 10yrs ago you mentioned...
"If you can't find a post-'64 clamp assembly, you might take the whole mess to a local machine shop."
This is what I plan to do however pardon my ignorance but would the machine shop be able to open up the diameter the saddle bracket
(orig tilt tube/ clamps removed) if I take the entire motor to them?
or do I need to disassemble down to the single part...
Rgds,
Scott
Rgds,
Scott
