Monte Carlo update
jamundsen
Re: Monte Carlo update
Postby jamundsen » Tue Feb 16, 2016 4:43 am
Hi John R
Yes I glassed everything including the deck. The only lace the weave shows is where I overlapped the cloth on the deck. I did something wrong there. Not sure what happened. Where I overlapped the cloth on the sides it does not show. I used 4 oz for everything. If I were doing it again I would use 6 oz at least on the bottom.
John Amundsen
Monte Carlo
Lakeland,Fl
Postby mrintense » Tue Feb 16, 2016 6:22 am
I used 7 ounce on the bottom and 4 ounce on my transom. In both cases, the weave completely disappeared. The real issue with epoxy isn't so much the weave as it is getting the epoxy smooth enough. I added an extra layer of epoxy when filling the weave as I will give the boat one more smooth sanding. On the transom (the only brightwork on the hull ) I plan on overcoating with clear polyurethane which I am hopefully will lay on much smoother.
jamundsen
Postby jamundsen » Tue Feb 16, 2016 9:38 am
I top coated sides and deck with clear coat sanded and buffed. You'll want a pretty smooth surface to put the clear over. Otherwise any defects will show. Don't wait too long after application to buff. It gets really hard.
John Amundsen
Monte Carlo
Lakeland,Fl
rphil84
Postby rphil84 » Thu Jun 02, 2016 4:39 am
John,
Do you have final pictures of the boat?
jamundsen
Postby jamundsen » Thu Jun 02, 2016 12:37 pm
Here you go
Still working on swim platform
John Amundsen
Monte Carlo
Lakeland,Fl
jamundsen
Postby jamundsen » Thu Jun 02, 2016 12:38 pm
Swim platform
John Amundsen
Monte Carlo
Lakeland,Fl
Postby Roberta » Thu Jun 02, 2016 4:43 pm
She's a looker, John. :D :D :D :D
Zed1134
Postby Zed1134 » Sat Jul 16, 2016 7:11 pm
Was looking at building one of these, what is the width of a Monte Carlo when built?
"Letting your mind dwell too much on the past will create a prison it can never escape"
wingridr
Postby wingridr » Sun Jul 17, 2016 9:01 am
It's looking good John!
Zed, just in case John doesn't see this right away, if they are built per the plan, the beam is 7'6".
Postby kens » Sun Jul 17, 2016 4:43 pm
Looking cool
do you have any side profile pics of the boat with canvas top??
classy look
jamundsen
Postby jamundsen » Mon Jul 18, 2016 3:59 pm
I'm not happy with the top
It's going back for some adjustments
It's got plenty of room
John Amundsen
Monte Carlo
Lakeland,Fl
joshuab
Postby joshuab » Mon Jul 18, 2016 11:10 pm
All i can say is wow! :!:
jamundsen
Postby jamundsen » Sun Aug 13, 2017 1:11 pm
Almost ready for the Gathering
Dings and all
John Amundsen
Monte Carlo
Lakeland,Fl
Postby Roberta » Sun Aug 13, 2017 1:17 pm
Looks great, John
Roberta :D :D :D :D
Postby Bill Edmundson » Sun Aug 13, 2017 3:21 pm
John
I'll be happy to see you again!
