best glue for vertical bonding
Posted: Sat Jun 22, 2019 11:57 am
by BruceB
I am ready to glue the plywood sides to the chines and sheers. I have been using epoxy w/hardener with a peanut butter consistency. But, it still sags and could get pretty messes. I have seen epoxy and hardener in a caulk tube that says no sag, but it is pretty expensive. Lastly, there is 3m 5200. Any suggestions on what has worked for all of you?
Re: best glue for vertical bonding
Posted: Sat Jun 22, 2019 7:06 pm
by hoodman
What are you using to thicken? If you add enough thickener it won't sag.
Posted: Sun Jun 23, 2019 4:47 am
by JimmY
BruceB wrote: ↑Sat Jun 22, 2019 11:57 am
Gloves!
Posted: Sun Jun 23, 2019 7:26 am
by Bill Edmundson
I like the caulk tubes. Yes, they aren't cheap. Get an extra tip or two. Tubes come with a reusable cap. Throw away the tip and get another. It's fast you can put it exactly where you want to work. Spread the bead with stir stick.
Posted: Sun Jun 23, 2019 1:49 pm
by BruceB
Milled glass fiber
Posted: Thu Jun 27, 2019 8:56 am
by Sarnian
its expensive but system 3 gel magic is absolutely fantastic - it doesn't sag and is incredibly easy to mix
Posted: Mon Apr 06, 2020 7:22 am
by marlinmorris
I bought powerful glue for wood form Ritecoupons. It is quite expensive but result is best. P.S: don't forget to wear gloves while using glue, it may damage your skin.
Posted: Mon Apr 06, 2020 8:05 am
by chugalug
If you use Gorilla and get it on your hands,you'll know why they call it Gorilla.It changes you into one.That black stuff on your hands has to wear off
Posted: Mon Apr 06, 2020 8:29 am
by steveh41
System 3 Gel Magic is a great product for vertical or overhead bonding. The cartridge with mixing tip is quite a bit more expensive than buying in plastic containers...
Posted: Mon Apr 06, 2020 9:32 am
by parsj1957
I've had success minimizing the mess by taping the seams off like you would for painting - tape and a piece of brown paper - then the vast majority of any dripping/oozing epoxy runs out onto the tape and paper. Once it gels (stops dripping) I remove the tape/paper to avoid it being 'epoxied' to the surface -- not 100% perfect but sure minimizes the cleanup effort -- so for me its been a big net positive time tradeoff.
Posted: Mon Jun 08, 2020 8:52 am
by savingrite
The construction adhesives is an alternative solution for they can successfully bond on many substrates. We’re recommending the usage of LIQUID NAILS® in Ultra Qwik Grip {LN-990} to adhering to porous surface & LIQUID NAILS® FUZE*IT® In the all surface construction Adhesive (LN-2000) to the most surfaces for getting vertical material intact.
