Engine hatch hinges
What kind, options, etc.
Tony Hain
Engine hatch hinges
Post by Tony Hain »
I was wondering what other people have used for engine hatch hinges besides piano hinges. Pictures or webb links would be good. Thanks
Tony Hain
Re: Engine hatch hinges
Post by neel thompson »
I am going to try to figure a way to use the Carolina Triple Hinge on my PB. You would have a one piece hatch that you could open from either side. They are designed for hot rods, but I see no reason they couldn't be used in a boat. You would have two release buttons in the boat, one on each side. You select which way you want the hatch to open and set up the releases to make that happen. These hinges would not be visible from the outside. The third option is to release both sides to completely remove the hatch. I want a set of these for sure.
Here is the link:
http://www.carolinacustom.com/pages/pro ... s_page.jsp
If you are hinging along the curve of the deck, these are about the only choice, but they can also be used on a straight hinge line:
This is one source for them, but they are carried by several suppliers: http://www.piersupply.com/Item/H90-0400
On a curved hinge line, I think you can only use two hinges, but on a straight hinge line you could use more. Piano hinges kind of force you into hatch banding.
Rich Coey
Post by Rich Coey »
The way I did it on a curve ( it would also work on a straight edge ) is with 2 pins through bronze bushings held by clips. When the hatch is opened the rear drops down as the front goes up. To Remove the hatch, remove the clips and close the hatch, then the pins can be removed from the rear cockpit and the hatch can be lifted off.
Cheap and simple.
You can see the ends of the pins in the corners of the hatch
The back of the hatch drops down as the front goes up
Rich
steveh41
Post by steveh41 »
Rich,
That's totally cool!
Tony Hain
Post by Tony Hain »
Thanks guys. Some very different but clever approaches to the problem. I think I will have to plot my butt in a chair, look at the hatch and opening and have a think.
Tony Hain
Tony
It's called "Chair & Cooler" (CNC) time. :)
Return to “Fasteners”
