Missing patterns for poweryak 17
Ranman
Post by Ranman »
Hi All,
I started tracing my last patterns on my last sheet of plywood for the Poweryak 17. When I looked for the patterns for the hatch and the side decks I can't find them anywhere. I know some times finding things on the pattern sheets can be tricky but this is impossible. I also noticed that these three items are not numbered either like everything else was. Am I missing a plan sheet? It mentions nothing about this in the instruction booklet. Anyone have any answers?
upspirate
Re: Missing patterns for poweryak 17
Post by upspirate »
Can't think of anyone on the forum that built this....my guess would be to contact headquarters(Glen-l) on Monday and ask
Ranman
Post by Ranman »
I found the problem. The remaining pieces need to be cut last as they will need to be cut to fit perfectly into the near complete boat.
upspirate
Post by upspirate »
Good, usually enough info is provided SOMEWHERE on the plans/pattern sheets to build these boats.
At first it's confusing,but after it's built you look back and say " why didn't I see that before" !!! :wink:
Grand Chillin
Post by Grand Chillin »
It never hurts to use something else to make a pattern first so you can check the fit before cutting the good stuff. I have used luan, hardboard and large pieces of cardboard. Just my 2 cents.
liagleason
Post by liagleason »
Great!!!
Return to “Electric Power”
