ETM question
Posted: Wed Jun 12, 2013 10:12 am
by JYD
Hi gang,
I've got a project that I think would be perfect for the Glen-L ETM design. My problem is that I only have about 12 total inches of vertical clearance between the hull and the aft deck in which to fit the thing. Before I spend $45 on the plans and another $200 or so on a trolling motor, do you think that is enough room for this concept?
I'm not too concerned about water ingress as the thru-hull fitting should be sitting right at the waterline at that point.
Any input would be appreciated.
JYD
Re: ETM question
Posted: Thu Jun 13, 2013 2:53 pm
by Gayle Brantuk
JYD,
The ETM plans show the motor mount to be 11" or "as required". So you know, this unit is not quiet like an electric motor--I think it's due to using the lower unit of the outboard...
Re: ETM question
Posted: Fri Jun 14, 2013 9:01 am
by JYD
Gayle Brantuk wrote:JYD,
Thanks for the response. Just to be clear, i was referring to design #410. It should be pretty quiest shouldn't it?
Re: ETM question
Posted: Mon Jun 17, 2013 2:29 pm
by Gayle Brantuk
Yes, that is what I'm referring to and no, it won't be quiet like a regular electric motor.
Re: ETM question
Posted: Wed Jun 19, 2013 9:52 am
by JYD
Gayle Brantuk wrote:Yes, that is what I'm referring to and no, it won't be quiet like a regular electric motor.
I am amazed. I would have thought that would be pretty quiet if not noiseless.
I can see where the following could be quite noisy:
Re: ETM question
Posted: Wed Jun 19, 2013 11:13 am
by khundley
JYD, what HP are you thinking? I have a 1 HP DC motor I am doing nothing with.
Re: ETM question
Posted: Thu Jun 20, 2013 12:12 pm
by JYD
khundley wrote:JYD, what HP are you thinking? I have a 1 HP DC motor I am doing nothing with.
Well, I was thinking about a 50lb thrust trolling motor, but now I'm wondering if that is a good idea.
Re: ETM question
Posted: Thu Jun 20, 2013 1:42 pm
by khundley
PM me if you choose to use the design above, I can get you the details.
Re: ETM question
Posted: Fri Oct 18, 2013 11:12 am
by Gayle Brantuk
I have to apologize here. My original comment about this being "noisy" was actually in reference to the Electric Drive (ED) NOT the ETM. So sorry for the confusion...
