Tom's Tahoe
Re: Tom's Tahoe
Post by mrintense » Sun Jan 05, 2020 4:27 pm
Sweet looking deck Tom!
Carl's Vera Cruise Build
Re: Tom's Tahoe
Post by TomB » Fri Jan 17, 2020 3:46 pm
Thanks Carl. The deck is sanded ready for varnish.
I happened to look under the boat. Gasp!!!!...the boat cradles needs some attention.
The furniture dollies have deflected about 3/8".
Re: Tom's Tahoe
Post by mrintense » Sun Jan 19, 2020 3:00 pm
It's surprising how heavy these boats get. I had to move mine out of the garage about two years ago, way before adding the flooring and cabin sides and it was so heavy that even with my daughter's help, we couldn't get it back up the driveway which angled down to the street..
Re: Tom's Tahoe
Post by TomB » Sun Jan 19, 2020 4:07 pm
The design hull weight is 1000#, engine adds 1000#. I figured that four 1000# furniture dollies gave me an adequate safety factor. Turns out the 3/4" mystery wood spreaders weren't up to the task. Adding some lumber to spread the load solved the problem.
I was having trouble pushing the boat around...now that the knock-knee'd casters are fixed it pushes better. If this boat went down the driveway and blocked the street, I'd have to wait for several neighbors to be inconvenienced. :D :D
Re: Tom's Tahoe
Post by TomB » Fri Feb 28, 2020 5:20 pm
Making a little progress on seats. Still needs sanding, varnish, seat foam, upholstery, and maybe a grab bar along the top. Other that that, they're done. :D.
The bases are just tacked together so I can see how they look.
Bluesman
Re: Tom's Tahoe
Post by Bluesman » Fri Feb 28, 2020 5:22 pm
That looks really good Tom! Where did you get the hinges?
Re: Tom's Tahoe
Post by TomB » Fri Feb 28, 2020 6:01 pm
Thanks, Tecla Boat Fold Up Brackets MF3118 from Great Lakes Skipper. I don't think they carry them now. Tecla sells direct too. Tom
Re: Tom's Tahoe
Post by JimmY » Fri Feb 28, 2020 6:29 pm
Nice work on the seat sides, I really like how they pivot.
Re: Tom's Tahoe
Post by Hercdrvr » Sat Feb 29, 2020 3:48 am
This is such a 1st class build. Very nice!
Re: Tom's Tahoe
Post by TomB » Sat Feb 29, 2020 10:36 am
Thanks Jim & Matt.
This is what I have in mind for the seat foam.
Steering wheel clearance...moving the seat base back a couple of inches to where I'm most comfortable anyway.
The 1/2" plywood edge won't give enough support for the bolster in the up position. I'll have to add material to the bottom side of the seat frame.
Tony Hain
Re: Tom's Tahoe
Post by Tony Hain » Sat Feb 29, 2020 12:49 pm
Great work Tom. So I assume the driver's seat folding up is to allow you to stand/sit and steer at slow speed. For example, while docking.
Tony Hain
Re: Tom's Tahoe
Post by TomB » Sat Feb 29, 2020 4:07 pm
Yes and to make it easier to access the storage area in the seat base. Tom
acflynn
Re: Tom's Tahoe
Post by acflynn » Sat Feb 29, 2020 8:05 pm
Looking really good, Tom! Now we know what you've been working the past month! Is this seat option only for the pilot, or for both front occupants?
Re: Tom's Tahoe
Post by TomB » Sun Mar 01, 2020 6:27 am
Both front seats. Tom
Re: Tom's Tahoe
Post by TomB » Mon Mar 02, 2020 3:43 pm
And the rear seat.
With all the other curves in the boat I was afraid that going straight across the rear deck might not satisfy me so I used the deck camber to curve the deck opening, seat back, and seat. It is subtle but I like it so no need for the chain saw. :D
The sole will be carpet or vinyl. The ceiling and carling will be upholstered. The top of the seat back cushion will roll over the deck edge. The face below the seat?? carpet or upholstery?
The armrests need work...The vertical faces will be upholster and a bright armrest cap with cupholder will be on top. The stack up of clearances (3/8" to 1/2") for the fabric will come out the armrests so they need to be narrowed a bit. The height feels good but there is barely room to get a beverage can into the spot for the cupholder. Everybody knows that would be a problem so I'll take a little off the top.
