Squirt need skeg?
soaked
Squirt need skeg?
Post by soaked »
is a skeg needed on the squirt.
upspirate
Re: Squirt need skeg?
Post by upspirate »
I would say yes,or a fin,but you can build it w/o and add one later if you determine it's needed for you.
I did this on a lower powered TNT and never added the fin as I didn't think it was necessary with the smaller size outboard I used
It wouldn't be hard to add one after the fact
Iggy
Post by Iggy »
I'd think any lake-boat would probably want a skeg to maintain steering control. Squirt's got a pretty flat bottom. I'd think you'd end up sliding sideways at times where you probably wouldn't want to.
Thinking about it.. does a jet-drive squirt use a skeg.. or does it snap over pretty tight?
Ian (aka Iggy)
My Malahini Build
pamelalynne1
Post by pamelalynne1 »
I expect to be adding a skeg to my Squirt. The steering response is poor if I am above 3/4 throttle.
Post by vupilot »
Allen's Squirt does not have a skeg, you wouldnt know it going in a straight line but it skids through the turns in a really fun way.
It depends on how you want the boat to handle and after riding with Allen in his, I think its purely personal preference.
Mark45
Post by Mark45 »
No skeg on my Bingo, I like the way it turns. Slides just a bit, but that's the feeling I like.
