Pee wee build in Sydney
Re: Pee wee build in Sydney
Held a piece of scrap in place to support the stem in its proper position:
All in position and glueing the breasthook to the stem. Once dry I'll glue the stem to the frame #2:
- Bill Edmundson
- Contact:
Nice work, Chubs.
Thanks bill! If you saw the gaps up close though...
So this polyurethane glue looks pretty ugly while drying:
Glueing the keel in place:
I'm not sure what to do next, can anyone help please?
I guess the bottom battens are next.
I've been looking at the photos on HZChevy's build, and it looks like they are notched into frames 1 and 2, which makes perfect sense.
But in the plans, i can see cutouts (circled in yellow) for the bottom battens in frame 0 (aka the transom), and not in frame 1 and 2, as you can see in the attached images.
Am i missing something obvious here? Am i meant to make cutouts so the bottom of the battens is flush with the frames?
Glueing the transom together. I'm back with epoxy now after reading up on it vs polyurethane glue.
Coming along nicely Chubs. You'll be out in Sydney Harbour with the big boys in no time lol.
Yep hz, the dream is to take the daughters into sydney on this (or another glen-l) boat one day
So I got this to start yesterday, i'm still deciding if I'll use it to power this boat:
