Pee wee build in Sydney
Re: Pee wee build in Sydney
Post by chugalug »
Forget sumthing? :roll:
chubs
Post by chubs »
Yes the bottom piece is coming :) I just don't have the plywood yet. Still deciding what to buy
Cam052
Post by Cam052 »
What thickness was your frames in millimeters?
chubs
Post by chubs »
19mm I think.
So i screwed the frames to the building form, was I meant to do that?
chubs
Post by chubs »
Another perspective:
hzchevy
Post by hzchevy »
Looking pretty good so far chubs. I also screwed my frames to the building form. That way nothing moves.
chubs
Post by chubs »
Actually my frames are 22mm, cam.
Thanks Hz, glad I'm on track.
slug
Post by slug »
Just make certain you can access those screws for removal!
chubs
Post by chubs »
Finally got some ply to do the stems and transom:
chubs
Post by chubs »
Cut the pieces oversized, glued and screwed:
chubs
Post by chubs »
Then cut to size. I found my jigsaw wasn't so accurate when cutting through 36mm of ply:
ian bell
Post by ian bell »
When you have finished putting on your sides , will you have enough room to crawl under and unbolt from the form so you can flip the hull
Ian
chubs
Post by chubs »
The stem fits nice and snugly into the breast hook. Making slow progress!
chubs
Post by chubs »
ian bell wrote:When you have finished putting on your sides , will you have enough room to crawl under and unbolt from the form so you can flip the hull
Ian
I'll have to be careful about that!
Post by chugalug »
:D Could always do like I did on my Bo-Jest.Supported front and the 2 back corners then reach in with sawsall and saw off legs of build frame. :roll: Flip boat and remove rest of build frame.
