Fisherman
epiziali
Re: Fisherman
Post by epiziali » Tue Nov 12, 2019 6:02 pm
I'm starting to plan for skeg and spray rail install. Can anyone point me to some pointers on spray rails? Do most folks steam wood before bending? And curious about placement. Do you run them flush to bottom of boat?
Eric
Eric
Re: Fisherman
Post by Bill Edmundson » Tue Nov 12, 2019 7:01 pm
Eris
Sprayrails are usually right on the chine. Coming around the bow the bottom edge is perpendicular to the side of the boat. They actually turn down. As you pass the widest part of the beam, they start to turn and become flat with the bottom.
epiziali
Re: Fisherman
Post by epiziali » Wed Nov 13, 2019 12:20 pm
Thank you. Think I am getting the idea. And I just found the detail on the plans. I got it. :D
Eric
Biss
Re: Fisherman
Post by Biss » Thu Nov 21, 2019 2:53 pm
viewtopic.php?f=2&t=33390&start=60
Boat is looking great. Above is a link to some posts showing the spray rails and skeg on my build. Hopefully you can see what Bill was explaining about how the spray rail is on plane with the bottom of the boat then then starts to turn down as it goes forward.
Biss
epiziali
Re: Fisherman
Post by epiziali » Mon Nov 25, 2019 6:27 pm
Yes...I can see that. That is what I was envisioning. Thanks for confirming. I have it installed. Unfortunately I goofed on the right side with snapped a couple of screw heads off. I should not have used washers. Oh well. I'll recover and get to shaping.
Eric
epiziali
Re: Fisherman
Post by epiziali » Mon Dec 30, 2019 10:14 am
I am debating glassing in splash rails and skeg. It seems like a lot of resin in the gap without glass to keep it in place without wanting to crack or chip out over time. Any advice on this would be helpful. Both splash rails and skeg are fastened with boat life / life caulk. Then I just used resin to fill in. Anyone else use fiber glass cloth on splash rails? Thank you.
Eric
Biss
Re: Fisherman
Post by Biss » Fri Jan 03, 2020 10:06 am
I didn't use fiberglas. I just used thickened epoxy and screws to attach. I think most consider the skeg and spray rails sacrificial. I guess it would be alittle easier to replace if there was no figerglas to deal with. Probably be a pain either way!
BarnacleMike
Re: Fisherman
Post by BarnacleMike » Fri Jan 03, 2020 12:41 pm
For my part, I would not fiberglass the spray rails & skeg. It would be a lot of extra work for very little actual benefit. Also, when the time comes to repair the spray rails & skeg, fiberglass would only make things more complicated — again, for very little actual benefit.
Re: Fisherman
Post by Bill Edmundson » Fri Jan 03, 2020 2:08 pm
You can make the skeg and sprayrails from solid PVC.
epiziali
Re: Fisherman
Post by epiziali » Mon Jan 13, 2020 1:39 pm
Thank you for the feedback.
The flip has happened. :D Finally.
Eric
Biss
Re: Fisherman
Post by Biss » Tue Jan 14, 2020 5:41 am
Looks great! Congrats on the flip. That's a big milestone in the build. Look forward seeing what you do with the remainder of the build.
Gayle Brantuk
Re: Fisherman
Post by Gayle Brantuk » Tue Jan 14, 2020 11:46 am
Awesome, Eric! She looks great--congratulations.
