Fisherman
epiziali
Re: Fisherman
Post by epiziali » Tue Apr 23, 2019 9:07 am
I have the final two pieces rough cut and starting to think through how to attach. Also thinking through where the transition point will go on stem. I mocked up a few scrap pieces in these photos. It looks like the transition should be a little further down the stem so I ensure I have enough meat left on ply where it will be fasten to stem. I had envisioned the transition point to be approx where I have it in pic...but I am thinking further down would be better.
Eric
Biss
Re: Fisherman
Post by Biss » Wed Apr 24, 2019 5:36 am
Here are a few pics of how I did it on a Malahini.
I basically just picked a spot and went with it!
epiziali
Re: Fisherman
Post by epiziali » Wed Apr 24, 2019 6:05 am
Thanks. Those are helpful pictures. Is that 3/8” ply? I just started the fitting last night. It’s challenging to bend it around the stem. I tried placing a few screws in to hold in place and trim but it just popped. I figured out how to clamp it. But not sure how I’ll do the other side.
Maybe a two man job. Or maybe I should call in an expert... 🤔🤣not sure. (That’s my humor)
All feedback welcome!
Eric
Biss
Re: Fisherman
Post by Biss » Wed Apr 24, 2019 6:22 am
Yeah, the bottom planking is 3/8. It is not easy to make those tight bends on the bow. I used boiling water and towels to help convince the ply to bend. Below is a link to my build page that shows how I did this on my project. Best of luck finishing up the planking!
http://www.glen-l.com/phpBB2/viewtopic. ... 0&start=15
epiziali
Re: Fisherman
Post by epiziali » Wed Apr 24, 2019 10:51 am
Your boat looks amazing. Thanks for all the tips.
Definitely felt like a wrestling match last night. I'm sure I work through it.
Eric
Re: Fisherman
Post by hoodman » Fri Apr 26, 2019 7:38 am
The boiling water/towels trick really works. That's about the only way you're going to get the 3/8" ply to bend in that area.
epiziali
Re: Fisherman
Post by epiziali » Fri Apr 26, 2019 10:53 am
Thanks
I kinda had to hit pause button and plan out some steps.
I can get the wood to bend. My fear is getting it to stay on the frame or even cause a breakage to frame once its attached. There will be a tremendous about of torque and tension on the frame from the ply.
So...here is what I am thinking.
I can back the chine from frame 3 to breasthook with additional mahogany and beef up stem with another 3/4" ply on each side. This will accomplish two things. 1) give me more surface area for ply and frame to come into contact with, 2) I can use longer screws.
I am thinking through a clamping system that will work for both sides. Shouldn't be too difficult, just time. Of course I have do to some more fairing to battens and stem...learned that after I fit ply...will make some progress this weekend, but it's a busy one...soccer, dance, pool party, and building pine wood derby cars with the girls. :D will be a fun weekend regardless...
Eric
epiziali
Re: Fisherman
Post by epiziali » Tue May 07, 2019 2:23 pm
Hello Everyone,
I have not made much progress since last post. Still concerned about attaching plywood.
On the one hand I reasonably confident that I can get it glued, clamped, and screwed on flush and tight. But still concerned it will pop off once I remove clamps. Should I be concerned???
Can anyone comment on whether or not the plywood can be steamed? I am using 3/8" okoume marine grade.
Was also considering scaring backside with saw blade 1/32" to 1/16" every 2" - 3" to take some of the tension out of it.
Any experience or creative thoughts on this?
Eric
Re: Fisherman
Post by DrBryanJ » Tue May 07, 2019 2:38 pm
I didn't need to, but many here have used towels and hot water to help bend the plywood. I think once it is screwed down and the epoxy has cured it is not going to pull itself free. As a matter of fact, I had to remove one of my plywood pieces. It was extremely difficult.
epiziali
Re: Fisherman
Post by epiziali » Tue May 07, 2019 3:39 pm
thank you Bryan. I did need to use the boiling water to get it on there. I've come so far, I would just hate to have it fail at this point. So if there is any other steps I could take to minimize a failure, that would be good to know. I'm sure there is a fix if it were to pop off, but definitely don't want that to happened.
Eric
Re: Fisherman
Post by hoodman » Tue May 07, 2019 4:11 pm
Once you get it screwed and epoxied down it's not going anywhere. The screws will hold it tight until the epoxy cures.
epiziali
Re: Fisherman
Post by epiziali » Tue May 07, 2019 6:48 pm
Thanks guys. Makes sense. I will run with it.
Eric
epiziali
Re: Fisherman
Post by epiziali » Tue Jun 04, 2019 8:38 am
One month later...I am well versed in patience and persistence. Glad to have this step done. I really struggled to fit last two pieces of planking. Needed five hands. Oh well, done now.
Eric
epiziali
Re: Fisherman
Post by epiziali » Tue Jun 04, 2019 8:41 am
Mostly happy with results. Not perfect. But it’s screwed down flush an tight with frame. I will fill in the gaps and get to glassing.
Eric
BarnacleMike
Re: Fisherman
Post by BarnacleMike » Tue Jun 04, 2019 9:59 am
Looks good!
Love the rigging with the clamps! Excellent!
