Steve B.'s ZZZIP Build
TAB
Re: Steve B.'s ZZZIP Build
Post by TAB »
Just remember, that white stuff turns in to blue stuff when it warms up.
Forge
Post by Forge »
Steve B. wrote:
Sun Dec 13, 2020 12:47 pm
Encapsulation...”Release the Schmoo”!!
Haha the Schmoooooo! :lol:
Encapsulation has been slow for me. The foam brushes fall apart after only 10 minutes. Did you have any better results?
Aerospace Engineer, Pilot, Sailor, Tinkerer and Surf Bum
Foam brushes aren't very durable. I buy cheap brushes for encapsulating corners and tight spots and use hotdog rollers for open areas.
Steve B.
Post by Steve B. »
I got 36 chip brushes on Amazon for $15. Perfect for everything including the encapsulation.
Building a ZZZIP!
Steve B.
Post by Steve B. »
Despite not being able to epoxy in the garage, I’ve managed to build the front and rear cockpit soles! I’m using 2” mahogany strips alternating with 5” quartersawn white oak. I resawed thicker stock to create bookmatched pairs then planed to 5/8”. (rear cockpit sole not shown in these pics yet). And also fit up the fore deck strongback and battens!
Building a ZZZIP!
laubenthal
Post by laubenthal »
Very nice!!That sole is really going to pop, I like the size and spacing you used.
Steve B.
Post by Steve B. »
I used the sizes and spacings that Joshua Burks used in his Zip build on YouTube. The spacings work perfectly so that the sole member along the chine (outermost) is a nice size after you scribe and trim it to shape.
Building a ZZZIP!
Steve B.
Post by Steve B. »
Varnishing the sole boards with JD Halcyon. Great product! Dries in an hour and water cleanup. I’m using it in my basement shop—a controlled environment— 65deg. Couldn’t be more pleased!
Building a ZZZIP!
Post by vupilot »
Good to know, haven't used that product before. That should definitely save a lot of time.
joshuab
Post by joshuab »
Looking great! Nice job.
Steve B.
Post by Steve B. »
Finally a break in the sub freezing New Hampshire weather! I built the gas tank mount platform, installed the varnished sole boards, carlins/seat back beams and even the radio box! Also most of the sheer fairing.
Building a ZZZIP!
Steve B.
Post by Steve B. »
With the return of nice weather I have been back at the Zip! Finished the sole, armrests and seats!
Building a ZZZIP!
Steve B.
Post by Steve B. »
And this guy...
Building a ZZZIP!
Steve B.
Post by Steve B. »
Dash and instruments.
Building a ZZZIP!
Steve B.
Post by Steve B. »
I decided to tackle my own cutwater. Im glad I did. Wife calls it “Boat Jewelry”. The project was my first metalworking project. I cut the steel from 18ga SS 316 and fitted it per the Cutwater Guy’s recommendations. I made a wood form from spacers to mimic the stem dimensions, then had it welded locally. After much grinding, sanding and polishing, the results speaks for itself. Its a perfect fit!
Building a ZZZIP!
