Fairing Issue
Jim Anderson
Fairing Issue
Post by Jim Anderson »
In fairing the chines, risers, and sheers for side planking, I had to trim the chines from form #3 (most forward form) to the stem to only 1/4" thick on the bottom edge. It looks too thin for bottom planking. I didn't get the importance of beveling the form notches, so the chine stuck out too far. I think I can laminate a 1/2" doubler to the chine (whole length) on the inside by cutting back the form notches. Sound OK?
Re: Fairing Issue
Post by Roberta »
Often longitudinal pieces get faired to triangular shapes and get pretty thin to get fair. Perfectly OK to add laminated backing to regain strength. Sometimes you need to add to the outside and re-fair. Fairness and symmetry is what you want.
Re: Fairing Issue
Post by JimmY »
Roberta is correct and brings up a good point on symmetry. Measure from your centerline to each sheer and chine midway between the last frame and the bow. Make sure the measurements are equal and make adjustments now, or this can affect your deck layout.
Jim Anderson
Re: Fairing Issue
Thanks Roberta and Jimmy. I'll take your advice and check the center line abeam measurements and compensate if necessary now. Learning a lot, this is fun stuff.
