Mr John battens order of operations
Big Boat Guy
Post by Big Boat Guy »
I have my battens ready to go down on my Mr John. The hull is not yet primed or painted. I’m planning to paint the hull and varnish the battens. Should I paint the hull and varnish the battens then attach them? I think this may visually look the best. Alternatively I can attach the battens now where I’ll know I’ll get a good bond. Then later I’ll tape them off, paint and varnish. Thanks for your thoughts.
Evan
Re: Mr John battens order of operations
Post by Evan »
I vote for gluing first. If you get any of the varnish/paint on the joint won't be good. Also you will likely get a bit of squeeze out at the joints so you would have to do some touch ups anyway.
Are you going to encapsulate the inside and outside of your boat? If so, encapsulate them and them on the inside surfaces.
Big Boat Guy
The outside is encapsulated. I was planning to just prime and paint the inside.
