Building The Vera Cruise
denbrlr
Re: Building The Vera Cruise
Post by denbrlr »
Carl,
Your boat is looking great. Keep up the good work.
Lee
Thanks Lee and Jim
Back problems are continuing to slow me down, but not stop me. I've got the port side skins cut to shape now.
BayouBengal
Post by BayouBengal »
You're just so close to slapping on motor on the back of that bad boy and taking her out for a cruise. I might have to take a road trip to Austin.
BayouBengal wrote:
Fri Aug 16, 2019 4:47 pm
:D :D
Well there's still quite a bit to do. For one thing, none of the interior is even installed! But it is exciting to see it coming together. You're certainly welcome to come by an see her if you're in the area.
psychobilly
Post by psychobilly »
Sounds like you need to come see my chiropractor in Houston. Look him up on YouTube. Dr Gregory Johnson.
#RingDinger
Vera is looking Vera-nice!!
Thanks Billy. I have been getting ongoing treatment, but it's a slow process.
Today, didn't have much time to work on the boat, but one of the next things I want to do is determine where to place the deck fittings. For me this means, four cleats per side, two fill ports (one for water and one for fuel) on the port side, and eventually bimini mount points. It also includes mounting points for the deck hatch lid hinges, the anchor well hatch cover hinges, possibly a flag pole, and deck lights (either in the center or two separate port and starboard bow lights).
I want to do this because I want to laminate a piece of hardwood to the under side of the deck skins in these areas to give the deck additional reinforcement. I'd like to do this before installing the skins.
So here are some pictures of what I am currently considering . At this point, all I have are the cleats and the fill ports. But what I would appreciate are comments on something I may not have thought of. Consider handling, usage, fender placement, etc.
The considerations I did make were ease of reaching the cleats from the various windows, keeping the fuel fill port (the aft fill port in the picture) away from the cabin, insuring that the two fill ports are in the correct place in relation to the interior water and fuel tanks, and trying to keep the cleats and fill ports in some sort of symmetrical relationship with one another. The distance from the edge is not a consideration right now since this is affected by the sheer. I am only concerned with the fore and aft placement and insuring that the cleats and fill ports are in the best place for boat handling.
The forward most cleat is of special concern. Does it need to be further forward? I was hoping to keep it within reach of the front cabin windows when they are opened to avoid the need to step out on the foredeck to reach it.
Thanks for any feedback on this.
I put the fuel port on the same side that it is on my truck. In my case that is the portside.
Looking good, Carl!
For cleat reinforcements, I epoxied them in place to the hull first and faired them in. This way they were tied into the hull structure. If you glue then to the skins, you will probably have to leave some clearance around them to make you can position the skins for final assembly and then you just moved the stress points around a little. It looks like the side skins are pretty narrow, once you locate the fittings I would mount a board between the sheer and the cabin side.
As far as cleats, definitely consider where you will need bumpers when tying up to the dock. I don't have a cleat at the widest point of my boat and it makes it difficult to protect it. Your positioning looks good for that. I think the forward cleat doesn't need to be farther forward. You might consider a center cleat with chocks on each side if you think you need to move the docking lines farther forward.
Not sure if you will be leaving your boat in the water for extended periods, but you really will want a solid mount for the cleats. They may have to keep 1000+ pounds of boat tied to a dock in a storm...
Bill Edmundson wrote:
Sat Aug 17, 2019 2:39 pm
I put the fuel port on the same side that it is on my truck. In my case that is the port side.
Thanks Bill, that's where it will be on my boat as well, although it's more a function of where the gas tank is going to be mounted.
JimmY wrote:
Sun Aug 18, 2019 5:55 am
Looking good, Carl!
Thanks Jimmy,
First off, other than an occasional night over, the boat will be stored out of the water. But I am planning on making fairly sizable backing plates nonetheless. Good point about the widest part of the hull. I will double check that before final placement. I will look into chocks and decide if I want them. I assume you are talking about the somewhat oval shaped deck fittings that are cut open across the tops to allow a rope to slide into. One challenge however for the center fitting is that there will be a big circular hatch in the middle of the deck.
I just traced the frame structure on the underside of the skins (which are already fitted) and will use that to pre-drill the mounting holes as well as determine the sizes of the backing plates.
Cleat positions look good. My take on cleat reenforcement is stout but not so stout it tears the deck off. I want my cleats to rip out before it yanks the deck off.
Your requirements may differ,
My deck cleats are backed by a second layer of ply and then I used thru bolts to attach the cleats.
Thanks for the feedback Matt and Matt.
I will be through bolting the cleats and the backing will either be hardwood or plywood, although I am now leaning towards plywood which I think will be better for this application. The cleats I bought are quite nice with two holes on the ends and a third hole in the center. All three bolts are supplied.
As for ripping off the deck, man, I sure hope I never have my boat in the kind of conditions that would do that! :D :D
Seriously though, I will be backing them up adequately and securely. That is the main point of this exercise, to determine the best location of the cleats and other deck hardware so that I can place the backing plates in the correct location.
I'm real happy with these cleats BTW. Nice quality and attention to detail in packing gives me confidence that they are well made.
Post by chugalug »
:D Wow! those are really nice;compared to the cast aluminum ones I got
I even got a couple little ones for fenders
I'm putting my deck fills away from each other(one on each side of the boat)
chugalug wrote:
Mon Aug 19, 2019 6:55 am
Both of mine will be on the same side, but I am separating them by about 6 feet . The fuel fill port will be the aft one and just aft of the side wings. Also, although it probably wouldn't be noticed, each port is identified by the type of liquid.
Post by Jimbob »
Hi Carl,
If I heard you right, you said both cleats on the same side of the boat. Don't forget, you can't always find a dock on one side of the boat. Think launch docks, and docks where one side is full. I would put two cleats on each side of the boat. Position them where the dock lines will be You will want them to be close to the bow and stern of the boat. For fenders, you can always get smaller cleats, and put them where the fender will rest. The curve of the boat will have a lot to do with where the fenders will be. Visualize where the boat might hit the dock. I have three fender cleats on each side of the boat.
p.s. I really like the cleats you picked out.
notice the small fender cleats at the beam between the cockpits.  There are also fender cleats at the bow and stern.
