modified malahini
chugalug
Re: modified malahini
Post by chugalug »
Don't plan on reusing the mix container as that stuff gets really sticky and hard to get out of containers when cured.Not sure what happens in colder temps but foam in a can won't set up too much.Don't glue yourself together if you get it on your clothing :D
Post by DrBryanJ »
Thanks for the advise Chug. I plan on using 20oz paper cups for mixing and pouring that I can just discard when done. Apparently this stuff likes temps above 75. Even my kitchen isn't warm enough. Either I wait until summer or turn the heat up.
chugalug
Post by chugalug »
don't overfill in enclosed spaces.will pop your boards loose.Might have to up heat.They say you save money by building your own boat.I Fibreglassed my boat in January so went thru 3 semi loads of wood for heating in boiler.At 1400.bucks a pop-wheres the savings?Sure is fun tho. :D
