Matt's Geronimo
Re: Another Geronimo Coming Soon
hoodman wrote: " anybody else that has built the Geronimo or Sea Knight it would be helpful to see some pictures of the transom/motorwell area."
Hi Matt
Craig Aho is building the Sea Knight. darthplywood (forum name ) also build one several years ago. There are also some real good pictures of the Sea Knight in the builder galleries.
Finally, I am building a Vera Cruise which is sort of a bigger Sea Knight and the hull is very similar to yours. I haven't got to the motorwell area yet but you are welcome to look at my construction blog and photo gallery at any time. I will answer questions if I can. Blog is at the link in my signature. Good luck with the build.
Thanks, Carl!
captkirk
Post by captkirk »
Here are some transom shots of my Geronimo. My topside is due for some refinishing...
Kirk
darthplywood
Post by darthplywood »
here's a pic of my motowell area (yes....my daughter is sitting-up asleep in the pic). It is cut deep enough to accomodate a 20" shaft outboard. I also used a custom aluminum motorwell to provide additonal strenght holding the motor on. It (ideally) distributes the stress a little more evenly on the inside of the transom caused by the through-bolts.
yet to come...11' Glen-L "Utility"
darthplywood
here's a couple more pics of the motorwell (one taken during the build from the outside of the boat).
Dang I'm finally to the point of cutting out frames. Thanks to the guys above who shared the pics of their motorwell areas. That will be a big help.
Question for geronimo/seaKnight builders: On frame 4 is the bottom frame member in two pieces? I am aware that the floor timber will be one piece but I am not sure about the frame member. It looks like it will need to end up being two pieces but I am not sure from looking at the patterns.
The Vera Cruise is two pieces. Since the Sea Knight and Geronimo are similar hulls, I suspect it is two pieces as well.
So there are a few frame parts that are about an inch wider than any of the widest boards that I have. Any suggestions? Can I glue an inch wide strip to the inside side of the parts?
Carl I suspect that it is two pieces as well.
jprice
Post by jprice »
hoodman wrote:So there are a few frame parts that are about an inch wider than any of the widest boards that I have. Any suggestions?
I had a similar issue with one of my frames. I used a biscuit joiner and epoxy to edge glue two boards together to make a wider board. I also reinforced the frame pieces after cutting them out by laminating a piece of 1/4" ply on one side.
That was probably overkill though, because I tested a piece of the edge glued board after the epoxy cured by smashing it with a hammer. It was always the wood itself that split. Not a single failure along the glueline.
hoodman wrote:So there are a few frame parts that are about an inch wider than any of the widest boards that I have. Any suggestions? Can I glue an inch wide strip to the inside side of the parts?
I think if the extra material is on the inside of the side frames it shouldn't be a problem. I'm not a naval engineer but most of the structural attachments are on the outside of the frames. You could back it with plywood as jprice mentioned.
The bottom frames are a different story. I think these would have to be reinforced.
BarnacleMike
Post by BarnacleMike »
Hi Hoodman. Congratulations on starting your Geronimo! I've always thought it was a great-looking design.
I was catching up on your thread & saw where you had asked about the System Three epoxies... I've used both the Silvertip GelMagic and the regular Silvertip, and I've got to say that I really like them both. The GelMagic is very viscous and is great for gluing parts together. The regular silvertip is very easy to use and apply for encapsulation, etc. You can also thicken it for gluing, patching, etc.
I only use the slow hardener. And, as GDCarpenter mentioned, sawdust makes a perfectly good thickening agent. I'll add this thought: I've used both mahogany sawdust and #2 silica to thicken epoxy. Any time I've had to remove dried globs of it via blunt force (ie a chisel instead of sandpaper), I've found that the wood-thickened epoxy tends to be more resilient. It absorbs impacts better than the silica-thickened epoxy. The silica-thickened epoxy tends to be more brittle. So, whenever I use epoxy to fill in less-than-perfect joints that are potentially subject to impact, I prefer to use the wood-thickened stuff.
Cut out the bottom frame member for frame 1. I can tell the white oak is going to make a super sturdy boat. Taking a close look at the patterns and my boards I think if I am careful I'll be able to eek out without having to scab on extra width for the most part. If I run out of the very widest of my boards I think the side members of frame 3 will be good candidates for scabbing and I can make all of the critical structural parts out of solid pieces. We'll see. I'm excited to be making a little oak dust.
Mike, thanks for chiming in on the epoxy. I haven't actually ordered any yet but will be soon. I'm thinking of trying out Raka, they have an economical non-blush epoxy. They're in Florida too so shipping costs shouldn't be too bad. I don't think I'll initially be able to use wood flour for thickener. I don't really have a good way of collecting it. I can hook up the shop vac to the table saw but I don't have a way right now to plug it into the RO sander (duct tape?).
Frame 1 is more or less ready for glue.
bobinpowayca
Post by bobinpowayca »
Hi Matt, I'm building the Geronimo. Started in Feb 2013. I'm in the process now of sheathing the hull. Yes, the bottom of frame 4 is in two pieces, joined by the floor timber. Bob
_______________
PBR support (1968)
