MI Malahini Build, Post Flip.
Re: MI Malahini Build, Post Flip.
Post by mrintense » Wed Jan 15, 2020 5:33 pm
Nice work on the cutwater and transom bands. Those always lend a nice touch to wooden boats.
Sarnian
Post by Sarnian » Wed Jan 15, 2020 5:39 pm
looks fantastic! - are you taking orders for cutwaters now? Let me know where to send my request. My welding started off well - but ended in disaster...havent added that bit to my story yet :mrgreen:
Post by DrBryanJ » Thu Jan 16, 2020 4:07 am
Very nice work. Wish I knew how to weld.
Post by PeterG » Thu Jan 16, 2020 7:17 am
Looks awesome!
footer
Post by footer » Thu Jan 16, 2020 9:45 am
Thanks guys. I finally got to the point in my life where I could by my own TIG, but my hands are no longer steady and my eyes strain to see through bifocals. So, it was challenging for me.
To avoid warping, I welded them in place, but had to run short beads. Even at that, there were a couple of points the paint and epoxy behind it caught fire. But, with enough sanding, I was able to make it look ok.
I polished the metal first, cut out the patters with a plasma torch, fitted and drilled them to the boat, polished them again, then welded , and started the whole process again.
There are videos on YouTube on polishing stainless to a mirror finish. It does work, but it’s not a quick as they make it look.
acflynn
Post by acflynn » Thu Jan 16, 2020 10:48 am
Very impressive! And that was before you showed the secret sauce - 7,000 grit? Whoa!
footer
Post by footer » Fri Jan 24, 2020 11:55 am
So, I found two problems with my lighting placement. I placed my forward nav light too close to my windshield ( because I thought it looked cool there) which glared badly on the windshield. I also bought blue lighted switches which are very bright at night. Between the two, it destroys my night vision.
So, I moved my nav light forward and am looking into a shield to block the blue lights on the switches. I put a docking light where my nav light was to cover the holes.
New placement with my docking light in front of the windshield.
Original placement of nav light. Caused lots of glare on the windshield. (Sorry, didn’t get a pic with the light on and the glare).
Sarnian
Post by Sarnian » Fri Jan 24, 2020 6:16 pm
Good to know. I have those blue switches too...
Mark-NJ
Post by Mark-NJ » Fri Jan 24, 2020 8:35 pm
Blue LEDs are annoying...and it's not just your imagination; there's science behind it:
https://blog.codinghorror.com/blue-led-backlash/
footer
Post by footer » Thu Jan 30, 2020 1:28 pm
Mark, thanks for that link. Quite interesting and explains a lot. I think I’m going to change to red because those blue are really annoying.
I’ve been working on my interior sidewalls which are a bit challenging.
So, last summer, I had a problem with getting on plane with four people on board and then pourposing when I got over 25mph.
I did a lot of reading and decided to go with these smart tabs I bought on Amazon. I am excited to see how well they work.
Starboard panel under construction with removable panels to run cables through and access wiring.
Smart tabs
Smart tabs
Inside port panel in place but not finished.
Sarnian
Post by Sarnian » Thu Jan 30, 2020 2:16 pm
those panels look great! - I am jealous that you're getting ready for your second season....
footer
Post by footer » Sun Feb 02, 2020 8:22 am
Inside starboard panel. An old sailing friend suggested I put vent holes in my panels, so I did. Bottom holes are for air.
Because the boat has a curve and twist, I built it right into the panel. This one fit perfect first try (the port side took a lot of adjustments). Of course things always fit differently after epoxy and finish is on. Keeping my fingers crossed.
Bow and twist set perfectly to fit right into place.
First coat of epoxy.
Panel fitted in place. Right the first time. Dang!
Biss
Post by Biss » Mon Feb 03, 2020 12:33 pm
The side panels are a nice touch. Hope the trim tabs fix your issues with porpoising. Seems like the Malahini really needs some weight farther forward to improve the CG. A big ice chest full of adult beverages under the bow may be the only solution!!
Biss
footer
Post by footer » Tue Feb 04, 2020 6:37 am
Thanks Biss. I’m excited to find out how well the tabs work.
I think your right about the CG. The 69 Merc I originally had, pulled a great hole shot with very little bow rise, where my new Merc (50 lbs heavier) has a lot of bow rise, porpoises, and struggles to get on plane with 4 people. Unfortunately, I can’t get any negative trim on my engine, it stops at vertical. So, I’m thinking the tabs should help.
denbrlr
Post by denbrlr » Tue Feb 04, 2020 8:49 pm
I think you will be happy with how the trim tabs work. Like I mentioned to you before, I installed them on my TNT and they work great.
Lee
