Pulling hooks question
footer
Post by footer »
So, I'm not sure if they are called pulling or towing hooks, but is there a specific location for these?
Re: Pulling hooks question
Post by billy c »
We always called them bow eyes or stern eyes depending on location. On the factory boats I've owned, they are usually pretty much in the upper third of the transom. We used them with a cable and pulley system that would go around the engine so we could tow water toys and skiers. They also were used for securing the boat while trailering and also seen them used to hoist the boat. So secure them where they are braced and maybe backed by metal backing plates ready for any abuse they are put under.
Billly
If you are planning a larger engine and pulling skiers, consider adding some gusseting from the transom framing to the shears and chines and do include a motor well to additionally reinforce the transom to hull connection. A "Y" harness with a float is typically used to connect the tow rope to the boat to prevent to rope and harness from getting caught in the prop. Setting the eyes 1/2 to 2/3 up from the bottom will even pulling stresses to better distribute loads and balance. Secure the eyes where they penetrate all the layers of the transom plywood and framing members and use backup plates on the inside and outside of the transom. Looks like the ones you pictured have two, one inside and one outside.
The eyes on the stern of my factory boat are located at a level a few inches above the bottom of the motor well and a few inches inboard of the side planking, comfortably above the waterline and clear enough of the side to get a wrench on the inside.
footer
Post by footer »
Thank you for the info. I have reinforced the transom and have a ski Bridle I use on our pontoon. I wasn't sure if there was a prime location formula for placement of the stern eyes, but it looks like, from ya'alls info, that I am on the right track. I will be using them for both pulling tubes/skiers and lifting the boat.
Thanks again.
