Kill Switches
Milhouse
Kill Switches
Post by Milhouse »
Jamie's harrowing story got me thinking about installing a kill switch to stop the engine if the driver goes overboard. I thought the lanyard type was the only option but then I ran across this wireless one. Has anyone used one? Thoughts?
It says you can pair 4 receivers to it so you get an alarm if someone falls over other than the driver and if the driver goes over it stops the motor. There is an override button so if there is another person on-board they can go pickup the driver.
Pros:
  • Might save a life
  • More likely to be used than the lanyard
  • Can alert to other overboard conditions than just the driver
Cons:
  • Expensive
  • More things to break
  • Have to mount another largeish thing
Fell Marine MOB+ Wireless Kill Switch
Traditional Lanyard Kill Switch
16' Ski Boat Restoration
17' Overnighter Sloop
Re: Kill Switches
Post by Roberta »
My Seastar helm came equipped with a deadman kill switch that uses a lanyard attached to the driver. It also has an integrated neutral safety switch to prevent starts in gear. So if you are still building and haven't purchased the helm control, consider one with these features.
Mine also has a safety button on the handle that prevents the throttle from being moved accidently and a shift release button that allows you to advance the throttle and not engage the transmission. Seastar CH1700.
CarlM
Re: Kill Switches
Post by CarlM »
Thanks for the info Roberta! I will keep it in mind when I get to that point.
Re: Kill Switches
I like that wireless kill switch especially since I never use the lanyard. I would be more likely to use the wireless one.
psychobilly
Re: Kill Switches
Post by psychobilly »
This came up on a fishing forum I hang out in. Looks like congress is passing a law, if not already passed.
I wear my kill switch every time I’m in my bay boat but I have never worn the lanyard in the ski boat. I like the faub idea but 200 bux ain’t cheap.
https://chesapeakebaymagazine.com/congr ... quirement/
Milhouse
Re: Kill Switches
Post by Milhouse »
psychobilly wrote:
Tue Aug 06, 2019 3:22 am
Wow - good to know
I found confirmation here
Another article which discusses some of the tragedies of not using one.
I just ordered the fob! I will post back observations (when the boat is on the water so it may be awhile!)
Milhouse
Re: Kill Switches
Post by Milhouse »
hoodman wrote:
Mon Aug 05, 2019 8:00 pm
Matt are you going to get one? I think its handy that you can alarm on the other fabs falling over as well.
Re: Kill Switches
I'm not sure. I think the simplest solution for me would be to switch to the PWC style lanyard that has the wrist strap. Often when I'm in the boat I am not wearing anything that I could clip the lanyard onto.
psychobilly
Re: Kill Switches
Well my particular type of Bay Boat hull is know for “swapping ends” due to its butcher knife bow and almost flat stern bottom with a tunnel. There was a Texas Game Warden that was severely chopped up by one years ago as it slung him from the boat when it swapped ends.
I also worked on a huge tow boat as a young man. One day I witnessed a wild man in a bass boat haul’n boogie. As he passed us his boat hit our wake and chunked him out. He WAS wearing the lanyard and the boat stopped as designed, and he lived to tell the story. Just a little sore.
I’m just scared of the wireless one. Battery dies on that thing you could be stranded. The lanyard is fool proof almost.
Heck, get it and give us all a report on how good it works.
Here’s some more reading on swapping ends if you’re interested. Note that the boat that they tested was not the same hull as mine but similar.
http://www.propellersafety.com/11976/re ... i-gorzell/
Milhouse
Re: Kill Switches
Post by Milhouse »
psychobilly wrote:
Thu Aug 08, 2019 5:29 pm
Wow crazy stories!
There is an manual override button on the receiver so if the fob goes out you can get it started again. Also useful if the driver goes over so the crew can start it back up and get thr driver. Edit it can be restarted 6 seconds after a MOB (man overboard) event without pressing the override button. Also there is a emergency jumper so if the unit fries one can unplug it and install a bypass plug to get it operational again...(just dont drive fast after this 😀 as there is no more kill switch feature).
The hub indicates low fob batteries 15 hrs before they die as well.
Im probably more likely to wear the fob but I get your points. Also it takes like 30 ft for it to know you left the boat so some tradeoff there as well the lanyard will cut it off immediately. Edit...the fob stops immediatly once submerged in 4 inches of water or after 30 ft dry or after the fob button is pressed.
Seems like they thought of it all. The instructions are pretty good. I got it delivered today from amazon after ordering last night...wow
I like the alarm feature for other passengers going over...
psychobilly
Re: Kill Switches
I’m looking forward to your reviews on it. Please post pics of the unit and faubs.
Re: Kill Switches
Interesting discussion. I too would like to hear more about this. I had planned on a safety lanyard but I am open to other ideas.
Joerpilot
Re: Kill Switches
Post by Joerpilot »
I will also continue to watch for updates. Sounds like a good idea.
Milhouse
Re: Kill Switches
Post by Milhouse »
psychobilly wrote:
Fri Aug 09, 2019 2:23 am
Here is a picture of it installed (not wired yet) with a custom wooden bracket (more pics of the bracket here)
Pic of the fob as requested.
I will be wiring it up soon.
Milhouse
Re: Kill Switches
Post by Milhouse »
I got the MOB wired up yesterday. It seems really well made and so far I really like it.
Here are my observations
  • I was able to pair the Fob really easily:
    • Hold button on MOB unit until it flashes blue
    • Then hold button ob FOB and then the MOB turns green
  • I now get one nice audible beep when the ignition key is turned on, a feature I was not aware of. Even if the MOB Fob is not connected it still beeps as a nice reminder that "Hey, Don't forget about the Fob, that's why I'm not starting"
  • Ways to enable the Ignition
    • Push the button on the FOB to allow ignition
      • There is a audible beep and the MOB flashes green and a LED indicating the Primary FOB is connected illuminates
        • Safety feature of MOB Fobs is ENABLED#SafetyFisrt
      • Push and hold the override button on the MOB unit for 10 seconds
        • Beeps and flashes yellow
        • Safety feature of MOB Fobs is BYPASSED #SafetySecond
      • Emergency Jumper: There is an emergency jumper, provided wit the unit and connected to the cable so it does not get lost. Just unscrew the connector at the back of the MOB and install the jumper cable. I imagine this is only needed for Open to stop ignitions (like mine). For a close to stop one probably just needs to unplug the MOB Cable to open the kill switch.
  • Ways to Cut the Ignition
    • Push the button on the FOB to inhibit ignition
      • Beeps and then all indicators go off
    • Out of range Condition: With the ignition active if I walk about 150 ft away then the ignition is cut
      • When it detects an Primary FOB Overboard situation like this then it cuts the ignition, Beeps and flashes red. then 6 sec after ignition inhibit it goes into override Beeps and then flashes yellow so another person can start the boat (hopefully to go get the overboard person) with no interaction with the MOB
    • Submerged Situation: Submerged in 4 inches of water per manual
      • I tried dunking it into a bucket but the manual says that does not work like that, it requires a larger body of water (Probably something to do with signal attenuation)
      • Per the manual it will behave in the same manner as the out of range condition
Typical Ignition enabled state. Will flash green periodically  on the top half of the LED Ring
