New member from upper Michigan
UPnorth
Post by UPnorth »
Hello,
I recently purchased a 2017, 21-1/2 foot, Glen-L Titian Tug that needs some engine and hull work. I am looking forward to your advice and guidance as I tackle the repairs.
Currently the boat has spent much of the summer with a good diesel mechanic who is installing a missing fuel return line, appropriate temperature and oil pressure sensors, and an appropriate alternator that is voltage regulated.
The next job is to address the fiberglass that has separated from parts of the hull, particularly the keel and a leak from around the brass fitting that supports the propeller shaft. Will share photos has I get started.
I am relatively new to fiberglass work and need all the advice I can get.
Thanks
UPnorth
Re: New member from upper Michigan
Welcome. How do you plan to use the boat? On the big lake? Tom
